Author Topic: which type of capacitor for pulsed discharge  (Read 4769 times)
Offline LaserTazerPhaserTopic starter
« on: April 03, 2019, 07:05:04 am »
Are there any electrolytics 360v-500v 540uf-1000uf which can fully charge & discharge @ ~0.714Hz?
Seems film will outlast electrolytic but by far are more expensive for the charge they store than electrolytics. Maybe a gang of electrolytics can do this.
« Last Edit: April 03, 2019, 07:20:19 am by LaserTazerPhaser »
Offline tautech
Re: which type of capacitor for pulsed discharge
« Reply #1 on: April 03, 2019, 07:32:26 am »
Pulse grade caps are used in electric fence units however their values are only 20-40 uF IME.
Most are 900 VDC rated and non polarized and always seem to be spade terminals.
It's not unusual to see gangs of up to 6 paralleled for a couple of 100's uF.
BTW, they are always marked as Pulse Grade.
The run for many years @ 1 Hz charge/discharge rate.
Try Tedds as they have some big grunty stuff for not too bad pricing.
https://www.tedss.com/Capacitors
« Last Edit: April 03, 2019, 07:34:30 am by tautech »
The following users thanked this post: LaserTazerPhaser
« Reply #2 on: April 03, 2019, 10:17:32 am »
What precisely depicts a "pulse grade" capacitor from non "pulse grade" capacitors?
These seem to be fine https://www.aliexpress.com/af/motor-start-capacitor.html?site=glo&g=y&d=y&origin=n&spm=2114.search0604.0.0.278f495eLHSZG8&filterCat=100006834%2C14191105%2C410405&jump=afs&groupsort=1&SearchText=motor+start+capacitor&SortType=total_tranpro_desc&isViewCP=y but they might pack undocumented features.
« Last Edit: April 03, 2019, 10:33:16 am by LaserTazerPhaser »
Offline Zero999
  • 0999
« Reply #3 on: April 03, 2019, 11:09:20 am »
Define fully charge and discharge? That may seem like a silly question, but a capacitor will never fully charge/discharge, unless it's a connected to a constant current supply/load.
You want low ESL and ESR for high current operation and if the duty cycle is high, then thermal design becomes a factor too.
« Reply #4 on: April 03, 2019, 11:40:15 am »
Capacitor is clamped to a load with a thyristor then recharged and to be discharged again at ~0.74Hz electrolytics aren't up for this.
« Last Edit: April 03, 2019, 11:54:34 am by LaserTazerPhaser »
Offline Berni
  • Country: si
« Reply #5 on: April 03, 2019, 11:53:44 am »
In that case you are only going to be discharging it at 2.75A (540uF capacitor going from 500V to 0V over 100ms)
This is not really a pulse capacitor anymore. Use something with low ESR and rated for plenty of ripple current and you will be fine. Tho such high voltage capacitors tend to not be available with really low ESR so paralleling 5 or so smaller ones is probably the way to go.
Pulse capacitors would tend to be designed for discharge rates of 100A and up.
« Reply #6 on: April 03, 2019, 11:56:50 am »
The load is very small and the current will rise well over 120amps. Only motor run or dc link capacitors seem to be up for this.
Offline tautech
« Reply #7 on: April 03, 2019, 12:34:50 pm »
Continuous pulse duty.
Start Caps are not for continuous operation.
Run caps will be a better choice although how they accept deep discharge might be anther matter.
AFAIK pulse grade caps are constructed similar to motor grade caps.
Same switching principle as used for electric fences where the charge is dumped into the primary of a transformer.
« Reply #8 on: April 03, 2019, 12:58:55 pm »
Are there any motor run caps above 100uF? Only the noname brands seem to go above 100uf which can be just motor start listed as motor run.
Offline tautech
« Reply #9 on: April 03, 2019, 01:08:32 pm »
Never seen one more than 60 uF.
Yes and if you use a Start one in a Run application they let out the magic smoke.  :scared:
Don't ask me how I know.  :palm:
For just the few $ they are I'd try some of the Chinese Run caps and see how they perform. If they get too warm you might have to use proper Pulse rated caps at more cost.
I looked at getting some a while back for a sick electric fence I scored but the cost was something like $30 ea IIRC and I needed a couple.
Found a crowd in NZ that manufactured them for the few electric fence manufacturers we have here that export worldwide.
Offline Psi
« Reply #10 on: April 03, 2019, 01:28:52 pm »
You could make a nice capacitor array with lots of Cornell Dubilier - 942C   2.5UF  600VDC  high pulse rated caps in parallel.
http://www.cde.com/resources/catalogs/942C.pdf
But that would probably be a bit overkill for your requirements :)
They're 628 volts per microsecond dV/dt :D
and a pack of 200 caps to get 500uF 600V would allow ~40 million amp discharge current.
« Last Edit: April 03, 2019, 01:31:09 pm by Psi »
The following users thanked this post: tautech, LaserTazerPhaser
« Reply #11 on: April 03, 2019, 01:35:08 pm »
Id buy this https://www.ebay.com/itm/282977692008/ but its way too large for the application and will destroy the load from overheat or even melting.
The issue with massive ganging is the cost at which point I would rather buy a dc link cap from a reputable retailer.
I only need ~5 of these https://www.ebay.com/itm/6003058083 but its likely loaded with undocumented features - infact its documents are likely nowhere to be found also takes up quite a lot of area.
« Last Edit: April 03, 2019, 01:56:45 pm by LaserTazerPhaser »
Offline Marco
« Reply #12 on: April 03, 2019, 01:52:32 pm »
Meaningless question, the power dissipated in the capacitor is load dependent ... i^2*r and all.
Lets round off well over 200Amp to mean a 0.5 Ohm load ... that's in the same region as a cheap electrolytic in that range, so you'd be burning around 50 Watt, which would make it explode.
« Last Edit: April 03, 2019, 02:03:03 pm by Marco »
Offline StillTrying
  • Country: Broken Britain
« Reply #13 on: April 03, 2019, 02:47:52 pm »
Photo Flash capacitors ?
« Reply #14 on: April 03, 2019, 02:53:58 pm »
A few simulations showed massive capacitor power dissipation at 100khz of ripple (1.8a peak) with only ~800mA of rms current. There are many capacitors which can handle much more than 800mA of ripple but 90W of dissipation per charge and @ 0.74hz seems too much.
Maybe electrolytics are fine for this but even photoflash capacitors aren't made to flash any more than 0.5Hz and for a given duration beyond which they will degrade.
Offline madires
  • A qualified hobbyist ;)
Offline StillTrying
« Reply #16 on: April 03, 2019, 04:02:18 pm »
How are you measuring the cap dissipation. If I measure the dissipation in a 0.1R serparate from the cap. the dissipation peaks are ~1.4kW, at around 1% duty (because 120A lasts only 2.5ms) that's ~14W average.
« Last Edit: April 03, 2019, 04:04:08 pm by StillTrying »
« Reply #17 on: April 03, 2019, 10:40:36 pm »
The charging happens for ~1.1 - ~1.4seconds the 100khz charge period doesen't last 2.5mS and it repeats constantly after the capacitor is discharged.
« Last Edit: April 04, 2019, 08:14:59 pm by LaserTazerPhaser »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #18 on: April 04, 2019, 01:09:24 am »
You've provided no real information to make a decision on.  What is the actual application?  Circuit?  Waveforms?
The PRF isn't meaningful; if it's fractional-Hz at the most gentle possible waveform, the only thing that won't do is possibly supercaps, and definitely not batteries (for full cycles, that is).
Seven Transistor Labs, LLC
« Reply #19 on: April 04, 2019, 03:43:33 am »
Was it a no name brand cap? Those probably have inadequate or no safety measures implemented.
I was considering which capacitor is ideally suited for https://www.analog.com/en/products/lt3751.html massively powerful cap charger set to with 3.5amps peak 1.2amps rms at the secondary (shunt set to 9.8mR) it will run for hours and electrolytics might have disfavorable features for this application in which they cease to perform as a capacitor and in an ideal situation they have adequate safetey measures implemented. Its actually far more than 0.74Hz mentioned earlier with the 9.8mR shunt is nearly 1.9607Hz which puts even more of a load onto the capacitor. I just need >300v >32j per discharge cycle.
« Last Edit: April 04, 2019, 05:04:03 am by LaserTazerPhaser »
Offline T3sl4co1l
« Reply #20 on: April 04, 2019, 05:52:12 am »
:palm: That's literally half the application. Can you please tell everything?
Offline tautech
« Reply #21 on: April 04, 2019, 07:12:11 am »
The one I smoked was a start cap....they have a short duty cycle and the motor centrifugal switch removes them from circuit after a second for two at the most unlike motor run caps that are connected to mains while the motor is running.
In short (pun intended) a motor start rated cap is not rated for continuous connection like a run cap.
They may both look the same but are for different purposes.
Offline Gyro
« Reply #22 on: April 04, 2019, 09:11:24 am »
Typically, Motor start capacitors are 'thermally under-rated' bipolar electrolytics (to get the high capacitance) whereas Motor Run are metallized film, usually Polypropylene these days.
Best Regards, Chris
« Reply #23 on: April 04, 2019, 09:41:05 am »
You didnt mention the capacitor branding. Maybe epcos, kemet, avx or some other brandname makes entirely film wound start caps for long service life and low disintegration rates.
I suppose I didn't include load impedance which varies with thermals from 0.35R - 0.45R aside from that not sure what else you were looking for. Capacitor will be discharged into this load which is nearly identical as placing a screwdriver across its terminals due to the low impedance of the load. But the load wont be spot welded as a screwdriver would be since its attached to a large barrier terminal block.
« Last Edit: April 04, 2019, 09:48:07 am by LaserTazerPhaser »
Offline StillTrying
« Reply #24 on: April 04, 2019, 10:09:35 am »
A constant 1.2A charges 1000uF to 300v in 250ms, with only ~144mW dissipated if the ESR is 0.1R. Even at 2Hz it's less than 100mW average in the cap. so I don't think you need to worry too much about the cap dissipation during charging, just the discharging. :)
« Last Edit: April 04, 2019, 10:11:19 am by StillTrying »
