I'm running a sim of a trans-impedance amplifier that takes two current sources. I'm modelling my current sources as two exponential currents using the following parameters:
EXP(0 -20m 10n 500p 5n 250n)
- Initial Current = 0 A
- Pulsed Current = -20 mA
- Rise Tau = 500ps
- Fall Delay = 5 ns
- Fall Tau = 250ns
The two sources differ in their activation time by 25 ns, and they both go into a TIA to convert their current sum into a voltage. Straightforward, but I wanted to prevent from current backflow from one source to the other, so I'm thinking of adding a Schottky diode in series with my sources to prevent unwanted backflow, but I can't find a good Schottky diode model that would prevent backflow. What parameters should I look for here?
To add more information, while my current source is a simple, ideal one for testing purposes, the actual current source is a photodiode, two of them. Once they 'activate', they generate a voltage of -35 mV at the summing node, passing through the feedback resistor of the TIA to convert the current to a voltage signal. Given how the voltage difference is so tiny, should the diode forward voltage be tiny as well? The lowest forward voltage I found was 140 mV on Digikey.
