We seem to see on a regular basis devices that are supposed to provide 'free energy', these devices use a variety of technologies and have wonderful names but they all have one common attribute, they don't work. You cannot generate energy from nothing, it has to come from somewhere, and this is a rule that cannot be violated.
So, let us look at one example of a 'free energy' device.
Take a DC motor, attach the shaft of the motor to a DC generator, wire the output of the generator to a battery and wire the battery to the motor. The whole thing forms a loop and is the basis for all sorts of 'free energy' systems. So what happens? Your motor will probably start to turn but over a period of time (depending on the size of your battery) the speed will decrease until the battery is discharged and the motor stops again.
Why does the system not run forever?
In one word the answer is losses, but as this is the EEV Blog Forum we need some more detail.
1) The battery supplies energy to the motor. All batteries have internal resistance and this resistance means that some of the battery energy is dissipated as heat and energy is lost heating the surrounding air.
2) The motor turns but, even with good bearings, there is friction, and this friction is turned into heat energy. The windings of the motor have resistance (as do the brushes) and this generates more heat rather than useful movement. Note that the motor is not silent, generating this sound energy also consumes electrical power.
3) The generator turns but, even with good bearings, there is friction, and this friction is turned into heat energy. The windings of the generator have resistance (as do the brushes) and this produces more heat rather than useful movement. Note that the generator is also not silent, generating this sound energy also consumes electrical power.
4) Finally, the wiring of the system has a small but measurable resistance leading to more useful power being turned into heat.
Fiddle around with this for as long as you like, but as Cmdr Scott used to say, "you cannot change the laws of physics". All systems (including closed loops) have losses, these losses produce wasted heat and energy is therefore lost to the environment. Add a DC-DC converter? losses, why do you think the heatsinks are there? Add permanent magnets? Then you get either no change or losses as you try to oppose a magnetic force somewhere, and there is no such thing as a monopole magnet unless you consider some VERY complex work done about a year ago
http://phys.org/news/2014-01-physicists-synthetic-magnetic-monopole-years.htmlSo, the next time someone appears to have come up with a 'free energy' device look carefully at their design and work out where the losses are, then walk away.
Reference:
https://en.wikipedia.org/wiki/Laws_of_thermodynamicshttps://en.wikipedia.org/wiki/Perpetual_motion
