ECL is still alive and well:
http://www.digikey.com/product-detail/en/MC10H101PG/MC10H101PGOS-ND/1478129 for instance, original 10k ECL.
Not sure what all variants used to be around that have since fallen out of favor...
I don't think RTL/DTL is any loss, as they were largely compatible with TTL(??), and simply technically inferior (relics from a time when every transistor was precious). If you need to find replacements that meet timing and pinout, have fun with that, but the functions and signals haven't gone away.
Likewise with almost all 7400, which were inferior to LS for the most part. Some things, like 7406, don't make sense, or can't be made, in other families (30V outputs!), so they stuck around.
Most of the esoteric 7400 have died off, and weren't remade in LS. All the important (and compatible) 7400/LS were also pushed into HC (and the related HCT, AC, etc.), as well as many of the cooler 4000 series functions. And then LVC and "Tiny" families and so on.
I wouldn't say it's so much a matter of things dying off, as things being streamlined. Requirements are always changing, so the demands of glue logic vary a bit, but the basics obviously have weathered well. The same is true in general at all levels of computing: from glue logic to 8-bit micros (4 bit, even!) and on up the ladder, the lowest level requirements will
never go away.
