Author Topic: power supply  (Read 6003 times)
Offline christos
  • Country: gr
power supply
« on: December 18, 2013, 07:40:35 pm »
i have a power supply..very big and i want to make a protective circuit..when i touch the (+) and (-)..can any one find a circuit that its cheap and easy to build?
Offline con-f-use
  • Country: at
Re: power supply
« Reply #1 on: December 18, 2013, 09:19:29 pm »
AC? DC? What voltage? What frequency? Protect what from what?
If you just touch one output (either plus or minus) and your power-supply is not grounded, you should be fine. Else you might need an isolation transformer or an RCD.
Offline christos
  • Country: gr
Re: power supply
« Reply #2 on: December 19, 2013, 01:57:29 pm »
dc ..its a short circuit protection
Offline NANDBlog
  • Current job: ATEX certified product design
Re: power supply
« Reply #3 on: December 19, 2013, 04:19:17 pm »
It is called "fuse". :rant:
Offline christos
  • Country: gr
Re: power supply
« Reply #4 on: December 19, 2013, 04:23:38 pm »
not fuse lol..every knows that..never mind..it uses transistor and some resistors so when the output makes a short circuit all the current flows to the transistor and the resistor..i think the transistors work like a switch in this case
Online madires
  • A qualified hobbyist ;)
Re: power supply
« Reply #5 on: December 19, 2013, 04:45:33 pm »
A current limiter or constant current mode?
Offline Skimask
Re: power supply
« Reply #6 on: December 19, 2013, 05:27:30 pm »
Maybe a crowbar?
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline Mandelbrot
Re: power supply
« Reply #8 on: December 20, 2013, 05:57:59 am »
Is there any particular reason you don't want to use transistors? What voltages/currents are expected across the output terminals? We really just need more information.
Offline Rerouter
Re: power supply
« Reply #9 on: December 20, 2013, 06:35:27 am »
buy a resettable circuit breaker, you wont be able to make a DC current limit without some kind of transistor
Offline christos
  • Country: gr
Re: power supply
« Reply #10 on: December 20, 2013, 10:36:10 pm »
i have a fried in germany  and he made a circuit only with resistors..he lived here in greece and i cant fiind his number now..thats why..he made one power supply for me from a pc and made that circuit in it and when i build my own with lcd display i could not find the power supply he made for me..if you dont know anything .thats ok..i just thought someone would know here :P
Offline Dave
  • Country: si
  • I like to measure things.
Re: power supply
« Reply #11 on: December 20, 2013, 10:59:38 pm »
Maybe a crowbar?
A crowbar protects from overvoltage, not overcurrent.
OP, you are going to have to cough up more info if you want any useful help. Engineers don't like guessing.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline Rerouter
Re: power supply
« Reply #12 on: December 20, 2013, 11:38:00 pm »
you still havent elaborated on just what the hell power supply it is you have? as for a possible current limit method such as your freinds,
if its a regulated power supply then you find a normal incandescent globe with a cold resistance low enough to drop about 2-3V at your ideal current, and a voltage rating higher than the supplies maximum output, you hook this globe in series with the output and move the feedback network of the supply after the globe so it still outputs the correct voltage for small loads,
when you exceed the current and the globe will start to get hot making its resistance increase limiting the current furthur, as an added bonus you have a nice bright indicator that your drawing excess current
Offline christos
  • Country: gr
Re: power supply
« Reply #13 on: December 21, 2013, 08:33:41 pm »
:P  its just a normal powe supply..never mind..ill just put some fuse and its done :)
he made that when the outputs touch each other..the current flow throu the resistors somehow..he used the resistor as a load for the current to flow..he had a LED as a warning so he could see if there was a problem in the project he made....
if you dont havee anything in mind how this works ..no problem..
Offline Rerouter
Re: power supply
« Reply #14 on: December 21, 2013, 09:10:23 pm »
ok next best guess for his, a lm317 regulator in constant current mode, plenty of info online about how to set up one of those, likely with a comparator to turn on the led, (these are active devices like transistors, so when you said no transistors i was working out a truly passive method)
Offline Simon123
  • Country: si
    • Youtube channel
Re: power supply
« Reply #15 on: December 21, 2013, 09:20:50 pm »
You can use transistor and current sensing resistor:
Calcuate what resistor you need with ohms law and connect output of transistor to rs latch and to relays, which disconnect output.
Offline christos
  • Country: gr
Re: power supply
« Reply #16 on: December 21, 2013, 11:54:01 pm »
There was no transistor or anything..olny 2 or 3resistors..if you dont know.anything about it..i just make one from the internet..simply
Offline Zero999
  • 0999
Re: power supply
« Reply #17 on: December 22, 2013, 12:50:29 am »
A simple resistor will limit the short circuit current but unfortunately, the voltage drop may be too high.
You can buy special PTC (Positive Temperature Coefficient) resistors which have a low resistance when cold and high resistance when hot.  Another name for these is polyswitch/fuse. The PTC resistor is connected in series with the load. Under normal conditions the voltage drop across the resistor is negligible but when it's short circuited, it heats up and the resistance increases so a very small current flows.
Here's a link to a typical datasheet:
http://www.vishay.com/docs/29085/29085.pdf
Offline TheBay
  • Country: wales
Re: power supply
« Reply #18 on: December 22, 2013, 02:34:29 am »
Seems like this guy doesn't want any help or listen to the suggestions given  |O
Offline Bored@Work
Re: power supply
« Reply #19 on: December 22, 2013, 06:44:46 am »
Wasn't that obvious from the beginning? Probably a bullshit PC power supply that should now magically become a lab power supply.
Offline christos
  • Country: gr
Re: power supply
« Reply #20 on: December 25, 2013, 02:24:31 pm »
well.. i used some fuses..if i find my friedns number ..ill ask him how he made the circuit with only resistors and ill post it here  thx
Offline christos
  • Country: gr
Re: power supply
« Reply #21 on: December 26, 2013, 06:32:14 pm »
sorry about that..its ok.. i used fuses
Offline techm
Re: power supply
« Reply #22 on: January 10, 2014, 07:17:37 pm »
For those still interested, I had been thinking about this also for my build and ran across a neat circuit using optocoupler, a transistor and a relay. Basically, the optocoupler internal light is powered from the output, when the + and - are shorted, the voltage across the optocoupler light is effectively zero (or close to it) so it goes out. On the other side of the coupler (transistor side) this removes the base current to the  NPN transistor which completes the circuit to the relay, opening it and shutting the power off. Place the relay before the optocoupler and it latches off. A simple momentary switch to restore base current to the transistor latches it back on. Here's where I found it:
http://www.learningelectronics.net/circuits/short-circuit-protection-for-balanced_14.html
I guess the potential drawbacks are having a relay on the output (and its mechanical bounce) and the fact you have to manually reset it, though I'm working on modifying that.
