Most bargraphs I've seen "dither"when confronted by a signal which is part way between two steps.
Obviously,they can be, & are, made in forms that do better,but not commonly.
Or the "bargraph" can be be replaced with a simulated analog meter.
Top end Amateur Radio Transceivers have digital display based "S meters" which are indistinguishable from a real meter---they even have the same inertia characteristics as specified for a mechanical meter in the same service.
But these are part of a generally very sophisticated device,& are not cheap!
High impedance isn't just available with DMMs--Old style VTVMs,& the later FET based meters have similar input Z,as does an analog 'scope (with a x10 probe).
As I implied before,such a 'scope in the DC input mode,& with the triggering set to"AUTO,makes a useful large scale DC voltmeter.
Back in the day,4 wire measurement was done with analog meters,as they were the only game in town!
