Author Topic: Why can I measure AC on a DC power supply?  (Read 18172 times)
Offline Mark LoukkoTopic starter
« on: August 16, 2015, 07:46:06 am »
I’m a beginner and this is my first post so I apologize if this turns out to be a monumentally stupid question ;-)
Why can I measure AC on a DC power supply? To show you want I mean I’ve setup the following test:
I made my DC power supply switch between 2 and 3 volts as fast as it can. It turns out it can do this around 4.5 times a second creating a square(ish) wave.  My first multimeter measures DC, the second measures AC and my oscilloscope shows the waveform.
The first multimeter reads an average of about 2.5 volts DC. This makes sense since I’m changing the voltage so quickly. So far so good.
The second multimeter shows an average of around 400mV AC.  The multimeter displays RMS and I’m not creating a nice sinusoidal wave so OK I guess this number makes sense but why do I see any AC at all?
The oscilloscope, when DC coupled, shows my square(ish) wave completely above 0 volts as expected. When AC coupled, half of my square(ish) wave is above 0 volts and the other half is below 0 volts indicating AC.
How can my second multimeter and oscilloscope show AC when the source is a DC power supply? From my understanding the definition of AC is voltage or current that periodically reverses direction (polarity). The DC power supply cannot change polarity.
I must be missing a fundamental AC concept here or maybe it’s just terminology.
Here is a link to a short video showing my setup: https://youtu.be/uvKTb98Qt8E
Cheers
Mark
Online IanB
Re: Why can I measure AC on a DC power supply?
« Reply #1 on: August 16, 2015, 07:52:57 am »
If your DC voltage is changing up and down in a cyclic way you can understand this voltage as a sum of two components: a pure DC bias component and an AC component superimposed on top of it. Your multimeter and AC coupled oscilloscope are able to remove the DC bias component and show just the AC component which remains.
In a more general way all periodic or cyclic waveforms can be decomposed into a sum of different individual frequencies. This is known as Fourier analysis. When one of the frequency components is DC (or 0 Hz) this is just a special case of the general situation.
Online IanB
« Reply #2 on: August 16, 2015, 07:59:28 am »
To consider an analogy, maybe you have visited the sea shore? The sea has an average level ("sea level"), but it has waves superimposed on top of it. The sea in general has a constant level ("DC"). But when the waves encounter, for example, a rock pool, then water sloshes back and forth in and out of the pool ("AC").
To take the analogy a little further, the sea level goes up and down with the tides over a period of hours. This is a low frequency "AC" component to the sea level. The waves on the other hand undulate with a period of a second or so. This is a high frequency "AC" component to the level. By Fourier analysis all the different frequencies in the water level could be separated out.
Offline TheAmmoniacal
  • Country: no
« Reply #3 on: August 16, 2015, 08:07:42 am »
I share your curiosity here (yes I'm a noob/amateur/idiot). I have a few questions:
1. What would happen if you add a diode on the output of the PSU? I assume nothing?
2. Alternating current literally moves back and forth, while changing DC moves in one direction?
3. What would a meter in AC+DC mode read?
Online IanB
« Reply #4 on: August 16, 2015, 08:38:39 am »
Another puzzle for you. Suppose you are in a car travelling at a steady 60 mph. While you are in the car, you swing a pendulum in the direction of travel so the that pendulum bob at the bottom of its swing is travelling at 20 mph. Does the pendulum bob ever go backwards? (Is the pendulum bob still swinging back and forth, or is it always moving forwards?)
« Last Edit: August 16, 2015, 08:40:58 am by IanB »
Offline Richard Crowley
  • KJ7YLK
« Reply #5 on: August 16, 2015, 08:51:44 am »
So your supply "switches between" (aka. "alternates") between 2 and 3 volts.
And then you ask why you are measuring "Alternating Current"?
You are measuring AC because you are generating AC.
You happen to have an offset of 2.5V which disappears when you AC-couple it.
As to why you are reading the particular numbers on your meters, that is a rather more complex matter of how those meters handle non-sine-waveforms.
  • Country: no
« Reply #6 on: August 16, 2015, 08:58:37 am »
If the AC part of this signal is "actually" swinging backwards would depend on your reference (if you are inside the car or outside it). Could you place the ground lead (reference) somewhere in this setup to eliminate the offset? (put yourself in the car to see it swing around 0?)
Offline dom0
« Reply #7 on: August 16, 2015, 10:06:08 am »
When your scope is AC coupled, you place a 22pF cap (along with a 10M resistor) in series.  Or similar values of R and C.
No, the 10-50 pF input capacitance always shunts the input (and scope designers take some care that it stays constant regardless of DC or AC coupling - if it changed, you'd need to re-compensate high-Z probes). The series capacitor in AC coupling mode is usually somewhere near 50-220 nF, depending on the exact L.F. cutoff, and does not load the source (since it is connected in series).
« Reply #8 on: August 16, 2015, 03:51:36 pm »
Hi Everyone,
Thanks for everyone's feedback. I'm heading out of town right now. I will read all the responses tonight.  :)
Cheers
Mark
« Reply #9 on: August 17, 2015, 05:32:19 am »
Again, thanks for everyone's comments.  I'm pretty sure this is just a terminology thing on my part.
Yes, I asked why I'm measuring "Alternating Current" because as far as I know the current never actually alternated or reversed its polarity.
The current still flowed in one direction, just at different amplitudes.
Here is another example but simpler than my previous one...
Place a 1.5 volt AA battery with a 100 ohm resistor and you get .015 amps of DC current.
Add another AA battery in series and we now have 3 volts and .03 amps of DC current.
Take one battery away and we are back to .015 amps.
My little brain tells me by removing the battery we simply reduced the voltage and current. The current never reversed or alternated its flow inside the wire. Or did it?  If so can somebody please explain?
Cheers
Mark
  • KJ7YLK
« Reply #10 on: August 17, 2015, 06:13:11 am »
"Alternating Current" does NOT imply that is is alternating around the zero reference.  That may be the most common kind of AC waveform you might encounter, but the definition does not require BIPOLAR in any way.
Online IanB
« Reply #11 on: August 17, 2015, 06:51:10 am »
Please reconsider the pendulum example above (post #4). Is the pendulum in the car swinging back and forth, or is it always swinging forwards, just at different speeds?
Offline Psi
« Reply #12 on: August 17, 2015, 07:32:09 am »
Thought problem for noobs....
If you have 2V AC and you connect a 12V battery in series what do you have now? 2V AC or unfiltered 14V DC   :popcorn:
« Last Edit: August 17, 2015, 07:34:30 am by Psi »
Offline vk6zgo
« Reply #13 on: August 17, 2015, 10:19:01 am »
Cheers
Mark
The multimeter doesn't care!------If the dc voltage goes on & off.or if you could switch very quickly between your one battery & two batteries in series,the meter will quite happily see  it as ac.
All it cares about is that there is a change in voltage ----it will see the difference between the two voltage levels.
In fact,if you connect your meter,set to ac volts,across a battery,at the instant you make the connection,the meter will attempt to give you a reading of that sudden change.
You can make a simple ac volt meter by connecting a diode in series with one of the meter leads of a dc volt meter.
You then only measure the average amplitude of the 1/2 cycle during which the diode is conducting.
DON"T DO THIS WITH THE MAINS!-------the chances of killing yourself,blowing up your meter or your diode are high!
"Half-wave rectifiers" as described above, tend to give some errors which can be resolved by using a "Full wave rectifier".
This causes each consecutive cycle to be in the same polarity,so a dc meter can read the average of the amplitude of all half cycles.
This  can be,(& is,in practical devices),converted to read in RMS volts------but more on that later.
This is how analog multimeters read ac,but the rectification is done inside the meter.
I'm not a DMM guru,but as far as I know the same thing is done in them.
You could measure both  1/2 cycles individually,then combine the results with software,but that means your Analog to Digital Converter (ADC)would have to have a greater dynamic range.(maybe this is done in some meters).
Offline Delta
« Reply #14 on: August 17, 2015, 10:44:03 am »
You created an AC signal riding on a DC offset.  Good question though mate, I hope the answers make sense, as this is an important fundamental to understand. 😀
« Reply #15 on: August 17, 2015, 05:36:13 pm »
https://en.wikipedia.org/wiki/Alternating_current says the definition of AC is "...the flow of electric charge periodically reverses direction"
My understanding of AC is the green line below.
where the electric charge in the conductor moves back and forth at some predefined frequency (E.g. 60Hz for wall plugs here in Canada)
So in my humble opinion I think:
AC = alternating current (electrons physically move back and forth in a conductor)
The "AC" setting on a multimeter simply reads a change in voltage. It does not care if the voltage is going positive or negative.
When the oscilloscope set to AC coupling it simply inserts a capacitor in series. The capacitor, when charged, prevents any more steady DC current from flowing. When the voltage does change the capacitor will discharge or charge allowing some current to flow again. The result shows up as "AC" on the oscilloscope. Just like the multimeter, "AC" simply shows a change in voltage.
If what I'm saying is correct this explains why my multimeter was showing AC connected to my DC power supply. It was simply reading the change in DC voltage. I thought it meant the voltage was reversing polarity. Silly me, I thought the A in AC stood for alternating. ;D
Online CatalinaWOW
« Reply #16 on: August 17, 2015, 05:49:07 pm »
Don't feel bad.  English is notorious for re-using words.  The meaning of AC has evolved in the 100+ years since it was first applied.  When originally used it really did mean alternating.  As our understanding of electricity grew, and we expanded beyond pure power applications we (as a profession) chose not to invent a new and separate word.  In the newer meaning the old version is a special case.  It simplified the language for those who understood, but left traps for the newly introduced.
« Reply #17 on: August 17, 2015, 05:53:00 pm »
From a perspective inside the car, yes the pendulum swings back and forth at 20 mph.
From a perspective outside the car the pendulum swings back and forth but while it swings back it loses 20 mph of forward momentum. When it swings forward it gains 20 mph of momentum. Just like AC current the average momentum/voltage is 0 mph/0 volts.
  • KJ7YLK
« Reply #18 on: August 17, 2015, 06:08:40 pm »
Yes, I don't dispute the textbook/dictionary definition.
HOWEVER:
1) One could argue over the "perspective" of "reverses direction". Again, I don't read that as REQUIRING the voltage to pass through zero at any time.
     Any more than saying that "I am returning to home" doesn't require you to go beyond your home and then back.
2) How a simple meter handles mixed AC and DC is undefined.
     If it is something that concerns you, then do experiments exactly as you are describing to "benchmark" how YOUR meter responds.
     Remember that each of them could be different.
« Reply #19 on: August 17, 2015, 06:12:58 pm »
Thanks, that does make me feel better ;D   I've learned a so much from watching Dave over the past year. He is 70% education , 20% entertainment and 10% waffling (ok that might be a bit low ;-) ).  There is so much information on the internet its sometime hard to decipher the actual truth. That's why I bought my own test equipment, I wanted to see what really happens doing simple experiments.
I probably should have titled this thread "What is your definition of AC?" :-)
« Reply #20 on: August 17, 2015, 06:24:02 pm »
Thank you! Your post made all the pieces fall into place for me. ;D  (well, at least until somebody shoots holes in my theory)
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #21 on: August 17, 2015, 06:37:27 pm »
Depends on whether your 2V AC source is inductively or capacitively  coupled to the (presumed DC source - battery)
Recharged Volt-Nut
« Reply #22 on: August 17, 2015, 07:46:27 pm »
I believe the 12V battery would cancel out the 2V AC and you would be left with DC oscillating between +13 and +11 volts.
For me, since the voltage is no longer going below 0 volts the AC component (electrons moving back and forth) is gone and you are left with simple DC changing in voltage.
The multimeter would read 2 volts "AC" simply because of the difference in voltage.
Lets reverse it...
12V AC with a 2V battery in series.
I think you would get a sinusoidal waveform from +8 volts to -4 volts.  There would still be AC but more of the waveform would be above zero volts now.  If you added another 4 volts DC  the waveform would be from +12 to 0 volts. No voltage is going below zero so my little brain tells me we are simply left with oscillating DC but the multimeter would read 12 volts "AC".
Offline Zero999
  • 0999
« Reply #23 on: August 17, 2015, 07:56:44 pm »
Lets reverse it...
Now you're just talking semantics.
It's perfectly correct to call a 2VAC power source connected in series with 12VDC, 2VAC with a 12VDC bias. In fact, even with the 12VDC bias present, the current will change direction because the cable's capacitance will still be charged and discharged as the voltage changes. Assuming conventional current flow, when the voltage increases, current will flow into the cable and when the voltages decreases, current will flow back from the cable into the power supply. This will happen irrespective of whether the 12VDC bias is present or not.
Offline eilize
« Reply #24 on: August 18, 2015, 01:53:14 am »
you forget something : your pulsating signal is an alternating signal +offset(=dc )
the average value of a alternating signal =0
