I understand that one of the basic design ideas of Self is how to make things cheap and simple. That's why cheap polar electrolytes instead of non-polar or instead of a film types. They work fine too if you just want to make things done and if you are fine with 0.00x % distortion instead of 0.000x %.
If we factor in the imperfections of human ears, The difference is negligible.
As to electros---there are millions of audio stages that use the polarised type with no ill effects.
I don't like them personally, from my perception of their possibly poor reliability but they seem to have "hung in there" for so long that there seems little reason to avoid them.
Non-polarised electrolytics can have quite poor ESR in my experience & are often large enough to be hard to use for replacement during repair.
It is only relatively recently that film capacitors of equivalent values have been small enough to replace low value electrolytics.
During the mid to late 1990s, the monolithic caps I used in values up to around 1uF or so were small enough to replace the myriads of electros around such values that Sony used in their equipment,
Any capacitance values much above that became prohibitively large.
Cathode bypass capacitors of around 25uF were extensively used in tube amplifiers, & were effectively in the signal path, as if they failed to a high impedance state, the cathode bias resistor would cause a loss of stage gain due to negative feedback.
If they "gracefully" failed, reducing their effective capacitance over time, the stage frequency response would deteriorate.
