I have a mp3 player where the charge port broke off. Also the internal battery was getting weaker, since i used it every day for the past 5 years.
I opened it and found the battery was a 3.7v LiPo, 700mah. Power consumption around 70mA.
Since I had some 18650 holders and a couple 3000mah 8A limit batteries. So i removed the LiPo and wired the 18650 holder to the battery connections on the PCB. (please note, I did check the battery voltage periodically, and never let it go below 3.9v)
It worked great for a few days until i noticed it was slowly getting quieter and quieter, and occasionally had a sound of static coming thru the headphones - ESD damage potentially?
Today i went to use it and noticed the volume, when put all the way to maximum - which is usually quite loud, enough to damage some earphones - barely audible.
I went to check solder joints and swapped the op-amp, but no improvement.
Did i kill it with ESD?
