A better question:
Why do some circuits use bizarre resistor values?
Meaning,
I've seen commercial prototypes where, whoever designed it, probably several engineers in piecewise fashion, picked an entire spectrum of different resistors, and I mean just for useless crap like pullups. 3.52k, 5.1k, 10.2k, 14.7k, etc. Often used only once at a time.
It's such a pain trying to maintain and work on designs like that, because you have to check every part that appears in the BOM, that the MFG/PN are present, correct, and consistent with the schematic value. And the pain propagates all the way through purchasing and assembly, even just for prototypes, because the BOM is polluted by all these useless single-quantity parts that could all be combined as a single line item of 20 x 10k resistors or whatever.
The worst part is when you try asking one of the "responsible" engineers, and they don't give you any justification at all. Because they know they have none. Or worse yet, it's some dumbassed excuse that's not even wrong.
You ask your project manager to change them, but then you'd have to ask the customer, because you're screwing with a bunch of stuff beyond the one part of the circuit you were asked to change. And obviously, all those little changes will cost more hours on the project, and time is money, right?
Alas, the 90-10 rule is present in all fields. The average engineer knows little, and fakes along well enough to maintain employment. The experts are few and far between, and often brought in to clean up messes like this (in "record" time and accuracy, no less).
On the plus side, I have no worries over my continued value...
