Author Topic: How does this drop the voltage down without a resistor?  (Read 621 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
« on: March 28, 2021, 07:38:22 pm »
This goes from live 220v to 24 or 17 volts. How does it do this without a resistor or regulator?
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline MikeK
Re: How does this drop the voltage down without a resistor?
« Reply #1 on: March 28, 2021, 08:05:17 pm »
What do you mean?...The zener is setting the voltage.
Offline themadhippy
« Reply #2 on: March 28, 2021, 08:26:30 pm »
the 330nf capacitor is  pretending to be a  resistor,the magic phrase to search for is capacitive dropper
The following users thanked this post: Beamin
Offline TimFox
« Reply #3 on: March 28, 2021, 08:39:47 pm »
Since the reactance of the capacitance is much higher than the load resistance (Zener or relay), it limits the current nicely from the high voltage source into the load.  A good capacitor will not dissipate power and heat up, while a 10 k resistor would dissipate about 5 W with 200 V across it.  That is approximately the reactance of 330 nF at 50 Hz.
