All 4 are in parallel, in 2 strings of 2 parallel transistors, likely done so they can easily have current limiting for each pair of 2, and 4 overall because it reduces the heat dissipated in any transistor, plus also allows them to offer a lower current units with the same basic circuit board, only changing the transformer and removing one of the pairs. That way the designers only have to match a pair of transistors at a time, and thus makes assembling easier. You can see the entire drive circuit is duplicated from Q2 to get the 2 drive circuits.
