Author Topic: How to do to have a signal of -30dbm SOLVED  (Read 853 times)
Offline GGMMTopic starter
« on: April 17, 2023, 02:29:23 pm »
Hello,
Beginner’s question
I need to test a spectrum analyzer I built
I must inject a -30dbm signal but never exceed 0dbm otherwise the input chip will burn.
I have a FY6900 generator, I would like to start from a 1V (or other if it's need)  signal, otherwise the one is in the noise if too low.
My research gives me that a -30dbm signal corespond at a signal of 0.02vpp or 0.0070711 vrms
see here: https://coretechgroup.com/dbm-calculator/
I only have a telonic 0-80db variable attenuator but 75 ohm.
It can be used and what value to put to have about -30dbm?
You tell me you plug in the generator on one side and watch the box with an oscilloscope before plugging in?
In short, your best solution
cdt
« Last Edit: April 19, 2023, 06:00:54 pm by GGMM »
Re: How to do to have a signal of -30dbm
« Reply #1 on: April 17, 2023, 02:36:33 pm »
the project is here
http://www.carnut.info/tinySA/tinySA.html
 I drew inspiration from this site to build it
it's a simpleSA
cdt
Offline coromonadalix
« Reply #2 on: April 17, 2023, 02:57:34 pm »
for this case  if you have friends or peoples who have professionals generators .... electronic shop ??
Offline BillyO
« Reply #3 on: April 17, 2023, 03:07:22 pm »
Speaking of sine waves...
-30dBm is 7.07 mV into 50 ohms.
If you cannot manage 7.07mV you could try 224mV through a 30dB attenuator into 50 ohms.
Here's a good resource for such things: https://www.ahsystems.com/EMC-formulas-equations/dBm_Volts_Watts_Conversion.php
« Last Edit: April 17, 2023, 03:13:40 pm by BillyO »
Online radiolistener
  • Country: ua
« Reply #4 on: April 17, 2023, 08:15:26 pm »
-30 dBm = 0.02 Vpp
But note that FY6900 shows amplitude for unloaded output and has 50 Ω output.
So, if you connect it to 50 Ω input device, you're needs to setup twice higher amplitude on FY6900, for -30 dBm you're needs to setup 0.02*2=0.04 Vpp. In such way you will get 0.02 Vpp on the output of FY6900 connected to your device input.
But note this is right if your device input has 50 Ω impedance, for other impedance you're needs to recalculate amplitude.
  • Country: ua
« Reply #5 on: April 17, 2023, 08:18:16 pm »
note that 7.07 mV is RMS voltage. But topic starter needs peak-to-peak voltage, because FY6900 doesn't support setup RMS voltage.
In short:
-30 dBm = 0.007071 Vrms = 0.01 Vpk = 0.02 Vpp
So, just setup 0.04 Vpp on FY6900 in order to get 0.02 Vpp on the loaded output and it will be -30 dBm.
PS: and don't forgot to setup sine waveform.
« Last Edit: April 17, 2023, 08:27:52 pm by radiolistener »
Re: How to do to have a signal of -30dbm SOLVED
« Reply #6 on: April 18, 2023, 06:48:57 am »
Thank's for your answer.
I understood well how to do , you can lock my subject
thank you
cdt
« Last Edit: April 19, 2023, 06:01:37 pm by GGMM »
