Author Topic: Why I do not like fractals on my LCD...  (Read 4658 times)
Offline hggTopic starter
  • Country: gr
Re: Why I do not like fractals on my LCD...
« Reply #25 on: March 04, 2023, 01:11:46 pm »
"Fungus" the forum user...  Was just joking...
Offline jpanhalt
« Reply #26 on: March 04, 2023, 01:37:35 pm »
So "We just found the culprit" was not serious?  What was the culprit?
Microbial contamination shouldn't be dismissed.  That is a significant problem in jet fuel, which has very little water present:
https://conidia.com/jet-fuel-contamination/#:~:text=Microorganisms%20found%20in%20aviation%20jet,that%20can%20accelerate%20metal%20corrosion
https://pubmed.ncbi.nlm.nih.gov/6029836/
  • Country: gr
« Reply #27 on: March 04, 2023, 01:41:57 pm »
Microbes need food.  What are they eating in there?
Offline jpanhalt
« Reply #28 on: March 04, 2023, 02:04:17 pm »
Anything with carbon and an electron acceptor (required for energy).  The electron acceptor can be an organic molecule, which is often called fermentation, or an inorganic molecule/atom.  When the latter is oxygen, what is called aerobic.  It is what humans do.
Of course, some other elements are needed, like nitrogen. Jwillis gave one example:
4′-Pentyl-4-biphenylcarbonitrile
  • Country: gr
« Reply #29 on: March 04, 2023, 02:16:58 pm »
Please do not tell me that I have a petri dish...
Offline RJSV
« Reply #30 on: March 04, 2023, 09:15:22 pm »
Hey, ...is that a DAVIS Inst. ?
(I wrote code went in the Davis Instruments, they had similar looking compass circle.)
   The pattern is also visible all through that LCD, although not pronounced distinctly.
  • Country: gr
« Reply #31 on: March 05, 2023, 04:05:02 am »
Spot on!   :-+
Its a Davis Vantage Pro2.  It has been working flawlessly for years.
This is the second unit though.  The first one stopped working giving
a PLL could not lock error or something similar.  I never found out the
cause.
Which part did you code?
Offline amyk
« Reply #32 on: March 05, 2023, 04:23:12 am »
Definitely looks like some sort of bacterial culture.
  • Country: gr
« Reply #33 on: March 05, 2023, 04:29:58 am »
It does, but I think is very improbable.
There is no water or some kind of food in there.
I've just sent an email to Davis as well to ask them if they had seen anything like
this on other customer consoles.
Online coppercone2
« Reply #34 on: March 05, 2023, 04:53:30 am »
I would just use one of these with a 0-24 v input
https://www.ebay.com/itm/363960461904
and put these for minutes and seconds
https://www.ebay.com/itm/192149233125
I think they make the mechanism overcomplicated for most clocks
« Last Edit: March 05, 2023, 05:01:48 am by coppercone2 »
Offline Gyro
« Reply #35 on: March 05, 2023, 09:24:39 am »
 Huh? ???
Best Regards, Chris
Offline MrAl
« Reply #36 on: March 05, 2023, 05:28:42 pm »
lol, no Jesus yet.
They all look like dots but not in any matrix formation.
I can also see a loner in the lower left.
I might have a look under the microscope.
It is also over the LCD segment.
Looks like a sea horse.  :)
Offline jpanhalt
« Reply #37 on: March 05, 2023, 05:59:23 pm »
I think you underestimate what some microorganisms can survive or even multiply in.  As two examples, look up Deinococcus radiodurans and chemolithotrophs.  Again, organisms living in jet fuel do no have much water available.
As for your second approach, I agree.  You don't have many options:
1) Live with it
2) Try to get a replacement screen
3) Trash it
4) If #2 or 3, then investigate what it is.  A decent microscope might reveal whether the defective areas are shaped like pixels or more amorphous.  Pixel ("point" ) defects are well known.  If amorphous, any microbiology lab could help identify whether bacteria, fungi, or something else.  Something else might include a change in form from liquid crystals to solid crystals.
Offline james_s
« Reply #38 on: March 05, 2023, 08:18:14 pm »
It's worth contacting Davis, they're an American company, they've made these consoles for many years now and they're not cheap. IMHO this is the sort of failure that should never occur no matter how old it is. I have the same console and the display is fine on mine.
  • Country: gr
« Reply #39 on: March 07, 2023, 09:45:25 am »
How many years did you have the console?
No answer from Davis this time and they always replied previously...
The LCD conquering continues non stop.  Previously there was a tiny dot on the bottom
and now there is a new colony.
Each dot once established does not change at all, very strange.
Here is also a photo lit from the front with the backlight off.
Offline BillyO
« Reply #40 on: March 07, 2023, 03:09:57 pm »
It's a fungus.  The same sort of fungus plaques lenses and optical surfaces of all kinds.  Not really unusual, but no greatly appreciated either.
With lenses and mirrors it can be usually be cleaned off before any real damage is done, but sometimes it's consuming the "glue" between layers.  These cases (an this is probably one) are usually untreatable.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline james_s
« Reply #41 on: March 08, 2023, 02:38:04 am »
I remember seeing people fixing similar looking symptoms by baking the display I think, and another by massaging the affected area with pressure. If the display is otherwise unusable it's worth trying.
  • Country: gr
« Reply #42 on: March 08, 2023, 03:58:00 am »
I might try heating it locally and see what happens.
Lets hope it its not planning to draw a world map...
Still no reply from Davis.
They are too busy with their new IoT console.
Online Bud
« Reply #43 on: March 08, 2023, 04:10:17 am »
What did they eat on the coated prism surface of my microscope ?
  • Country: gr
« Reply #44 on: March 08, 2023, 04:12:51 am »
Are you using it (kept it) in a humid environment or looking at biological samples?
Your microbes are more civilized..
Offline BillyO
« Reply #45 on: March 08, 2023, 05:09:00 am »
This thread is falling apart.
Look up https://en.wikipedia.org/wiki/Lens_fungus
  • Country: gr
« Reply #46 on: March 08, 2023, 05:34:17 am »
"The fungus thrives at temperatures of 10C to 35C[6] and relative humidity of 70% or more"
It never goes above 50%.
Offline BillyO
« Reply #47 on: March 08, 2023, 06:33:23 am »
Okay then. it must be aliens.
Oh, wait.  How did you determine the humidity in the LCD?
Meh.
  • Country: gr
« Reply #48 on: March 08, 2023, 06:45:11 am »
Maybe the inside humidity monitor helped a bit...   :)
Offline Fungus
« Reply #49 on: March 08, 2023, 12:50:34 pm »
It is forming an image of Greece!
It's a message from somebody trapped in a parallel universe.
