Author Topic: why is class A audio amp saturating?  (Read 3534 times)
Online SiliconWizard
Re: why is class A audio amp saturating?
« Reply #25 on: August 17, 2019, 03:55:26 pm »
I made the circuirt you see in the attrachment and I'm using a small radio as input, however for some reason the output is saturated on the positive side of the wave and can't figure out why
As it is, the speaker will see a constant DC offset voltage. Never do that. Not only will it hinder the speaker's performance a lot, but it will also draw an enormous and unnecessary power, and could eventually destroy the speaker, make the coil overheat (and maybe make the insulator melt), or at least warp the speaker cone. A series capacitor would be required here (with high enough capacitance because it will form an high-pass filter with the speaker itself).
Offline Audioguru again
« Reply #26 on: August 18, 2019, 01:23:38 am »
The output transistor will not play the signal if the speaker has a capacitor in series with it. When power is applied the speaker will make one POP sound as the capacitor charges then nothing after it.
Offline Zero999
  • 0999
« Reply #27 on: August 18, 2019, 07:51:58 pm »
I think the idea is to add a pull-down resistor before the capacitor. The problem with that is it it either: limits the voltage swing, if it's too higher value or burns a lot of power ,if it's low enough to ensure a large voltage swing. Using a current sink, as I mentioned previously overcomes this problem, but requires another transistor which could be better used converting the amplifier to class AB.
« Last Edit: August 18, 2019, 07:54:04 pm by Zero999 »
Offline fourfathom
« Reply #28 on: August 18, 2019, 08:50:23 pm »
(Attachment Link)
The current sink still has to continuously sink sufficient current to pull the speaker negative, so it's only somewhat better than the resistor when you are trying for a large output swing.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Online magic
« Reply #29 on: August 18, 2019, 09:11:21 pm »
CCS is significantly more efficient.
Do the math: how much current it takes to drive 8Ω load within 1V of supply rail, what resistance is needed for that, how much current will it waste when idle.
Offline Zero999
  • 0999
« Reply #30 on: August 18, 2019, 09:20:39 pm »
Yes, a constant current sink is much more efficient. To swing within a half a volt of the negative rail with a resistor, would require such a low value, the quiescent power draw would be enormous. I alluded to this in a previous post.
https://www.eevblog.com/forum/beginners/why-is-class-a-audio-amp-is-saturating/msg2618517/#msg2618517
Offline fourfathom
« Reply #31 on: August 18, 2019, 11:15:22 pm »
OK, I agree.  I said "only somewhat", but you're right, the CC source is "much more" efficient.
