The MOSFET is switching as fast as you are driving it.
But the drain
voltage is not dependent only on drain current. There is capacitance, which slows the rise, particularly at low load currents.
If you zoom in on the delay between gate voltage falling, and drain voltage just beginning to tick up, you'll see that the MOSFET is working quite quickly, under 100ns.
(You may even see the voltage reversing momentarily -- gate-drain capacitance pulls the drain down slightly!)
