I've been working on a simple morse transceiver for about 7.023MHz, I started out with a Peirce Oscillator from "Experimental Methods in RF design" Page 127, then added a emitter follower to buffer the signal coming from the collector, then a CE amplifier I designed to have a gain of about 15 with an approximately 200Ohm load. I mostly optimised for input resistance to match it to the output of the buffer, but then designed for the gain after that.
When I turn it on however all I see at the output is an inverted version of the same input with half the amplitude (blue trace input yellow trace output on oscilloscope). Disconnecting the CE from the buffer I see the expected bias and emitter voltages at 2.4 & 1.8 volts each, but upon reconnecting the emitter voltage rises to 4.7V.
I'm not entirely sure what I'm doing wrong here, but any advice would be appreciated.
