I have a wien bridge breadboarded with a split supply.
My filter network is 10k resistors and 470 nf caps. I get ~36 hz (as expected)
My gain is set with a 20k resistor from out to inverting in, and a 7371 lamp in series with my resistor subst. box to ground. I buffer the output withe the other half of the tl072 I'm using.
I have the supply set at + and - 2.5v
So if i increment the supply by 100's of millivolts, I have to adjust the gain of the circuit with my resistor box. If I raise the supply. I have to lower the resistor (raise the gain) to maintain oscillation.
Why? Shouldn't gain be independent of supply, at least at such low variation in supply? and shouldn't the lamp be dealing with this anyway?
