Author Topic: Why is the RSC resistor needed to sample the choke current in the system?  (Read 453 times)
Offline akea
Hello guys. Can u pls tell me Why is the Rsc resistor needed to sample the choke current in the system? Thank you
« Last Edit: May 05, 2019, 03:24:13 pm by akea »
Offline T3sl4co1l
    • Seven Transistor Labs
The system?
Seven Transistor Labs, LLC
Offline akea
in converter
« Last Edit: May 05, 2019, 01:29:04 pm by akea »
Offline soldar
Offline akea
Anyone knows Why?
Online mikerj
No one has any idea what you are talking about, you haven't even described the system you are referring to.
Offline akea
sorry about it. i have just uploaded the system
Online mikerj
The circuit seem to be incomplete, there is no inductor (choke) shown.
The device block diagram looks like an MC34063 switching regulator, is that correct?  If so the resistor is used to provide current limiting, if the voltage drop across the resistor is greater than 300mV the duty cycle will be reduced to lower output voltage and hence lower the current.  Without current limiting an accidental short on the output could destroy either the regulator or the load.
Offline akea
Yes its correct.Thank you very much  :)
