Author Topic: BYV32E-200 vs BYV32E-200P  (Read 757 times)
Offline essence25Topic starter
« on: February 03, 2020, 11:19:40 pm »
Hello lads,
Question,
Are these the exact same parts, original BYV32E-200 vs the mouser.com one which has a "P" at the end. Eg. BYV32E-200P can the P one be used in place of the non P?
Thank you!
Offline ArthurDent
Re: BYV32E-200 vs BYV32E-200P
« Reply #1 on: February 04, 2020, 12:14:02 am »
It looks like the 'P' version has an isolated mounted plate but the non P has the cathode connected to the mounting plate.
At https://www.digipart.com/part/BYV32E-200 scan down to the Arrow listing and click on the part numbers for more information.
Offline george.b
  • Country: br
« Reply #2 on: February 04, 2020, 01:29:22 am »
Offline ArthurDent
« Reply #3 on: February 04, 2020, 01:40:28 am »
The 'P' version should work fine with or without the pink insulator. The checker shows that the original parts is probably O.K..
The following users thanked this post: essence25
« Reply #4 on: February 06, 2020, 04:57:30 am »
Ok, I received the new part with the P and it is exactly the same. Tab still tied to center pin. It appears to be a newer model and works fine in place of the old one. Even though the old one is not dead. :-)
