My laptop came up with a notice "recommend replacement of battery pack". I've been expecting this for years, date code on the computer is 1110. They are cheap enough so I ordered another. I've been scavaging batteries from these packs for years so thought I might rebuild this one as a spare. I've built a micro based li tester and bad batteries have always been easy to spot. Popped the cover on the pack and each battery measured 4.27V, that seemed a little high for a pack that had been pulled out for days. Then I used a 3.9 ohm (about 1A) resistor as a load, 3.59-3.64V after 30 seconds. Unloaded the batteries still 4.26V after load test. Seem pretty good to me as I only run on line power. Am I missing something or does the laptop just have a timeout after so many years? If so, is there a reset?
