I am simulating a power supply I have designed in LTSpice, which is a buck converter feeding a half bridge LCC (not LLC) converter. In the buck output inductor, I get a waveform that overshoots (almost oscillates slightly?) then settles at steady state with required output current and ripple I designed for, but I am confused as to why the oscillation occurs. My guesses are that it is resonating with something, maybe the switch capacitance. As this is a current-fed topology I do not have the output capacitor and instead just have the bridge switches following the inductor.
Any suggestions on why this is occuring and how it can be remedied?
