Author Topic: Why my dc-dc buck converter is consuming 8mA of current with no load connected?  (Read 859 times)
Offline nishantnidariaTopic starter
I am using a TPS5430 buck converter on my PCB which is converting 12V to 8V, if i shutdown the buck converter using enable pin, it consumes only a few micro amps but if i let it enabled with no load connected, it consumes about 8mA constantly.
Datasheet: https://www.ti.com/lit/ds/symlink/tps5430.pdf?ts=1664439034845&ref_url=https%253A%252F%252Fwww.google.com%252F
According to the datasheet quiescent current should be 4.4mA (max).
My questions are:
Is it normal?
Is it consumption or power loss?
How can i avoid/fix it?
Thank you in advance for your help and guidance.
« Last Edit: September 29, 2022, 10:25:19 am by nishantnidaria »
Offline temperance
The data sheet states:
VSENSE = 2 V, Not switching,
PH pin open
Your device is switching.
Thank you for your reply, when we say "Not Switching", does it means the IC is active but there is no load connected?
Offline hubi
The 4.4mA is specified when the device is not switching. You measured 8mA while switching.
I am confused, what is the difference between "Switching" and "Not switching" ? understanding the difference will help me a lot i think.
Offline thinkfat
    • Matthias' Hackerstübchen
"Switching" means the internal MOSFET is switching on and of at the set frequency (500kHz). "Not switching" means the MOSFET is gated.
The "VSENS=2V" requirement means this 4.4mA figure is not achievable in reality. If you need a smaller no-load current, choose a different part.
Why? Because this condition is artificial. The regulator will switch off the MOSFET when the feedback pin is at a voltage higher than the internal reference voltage of 1.221V. But in normal operation, the feedback voltage will always be equal to the reference voltage. This is how the regulation works.
