Author Topic: Nanoamp current source troubleshooting  (Read 4398 times)
Offline Kalvin
  • Embedded SW/HW.
Re: Nanoamp current source troubleshooting
« Reply #25 on: May 10, 2019, 08:04:13 am »
If you have a light dimmer or similar nearby, the circuit wiring might act as an antenna and pickup the rectified 50 Hz mains from the dimmer (100 Hz ie. 10 ms).
The following users thanked this post: ZeroResistance
Offline ZeroResistanceTopic starter
« Reply #26 on: May 10, 2019, 08:24:56 am »
Excellent suggestion, I have a light dimmer at a distance of 2 feet but its load is switched off, and there are other light dimmers about 4 to 5 feet away.
I guess the best way to circumvent this is by using proper pcb layout correct? I have built the circuit on a dotter board, not the ideal scenario for a low noise circuit. Having said that can I add any external components to qwell that noise?
Offline Kalvin
  • Embedded SW/HW.
« Reply #27 on: May 10, 2019, 08:36:35 am »
Place the circuit inside a metallic cookie jar. Just make sure you have some insulation so that the circuit nor the battery won't short-circuit. Make holes for input and output signals/connectors and possibly a battery on-off switch. If you have some common-mode chokes at hand, you may also want to experiment with those whether they will help with reducing the noise. Anyway, I would first try the metallic container. And you will have some cookies, too :)
