Author Topic: Why place resistor in the ground?  (Read 1046 times)
Offline chancsTopic starter
« on: February 19, 2020, 10:25:44 am »
I came across this circuit today, which is a USB to DMX for lighting control. Can someone help me to understand why the designer wants to place a 33ohm (R11) resistor between the system ground and the output groud? Also, shouldn't there be a 120ohm resistor between dmx_a and dmx_b since a DMX cable has characteristic impedance of 120ohm.
930986-0
Thanks a lot.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Why place resistor in the ground?
« Reply #1 on: February 19, 2020, 10:44:24 am »
Presumably only signal currents flow through that resistor, and not even much at that, because RS-485 is differential.  RS-485 still requires a ground reference; it is not an isolated interface, the receiver can only read signals within 7V or so of local ground.
The point then, would be to provide a weak kind of isolation, allowing ground loop voltages to drop across the resistor, rather than draw larger currents through a lower resistance path, and without leaving it fully open which would all but guarantee the receivers see trash.
It should be bypassed with a capacitor, so that shielded cable can be used if available, preventing RF interference from getting into the cable.  As shown, the resistor simply drops some voltage (at some current), regardless of frequency, which in turn allows RFI into the cable.  It does however act to terminate the cable/shield, so it won't be as prone to resonances as it would be otherwise.  (If bypassed or direct-grounded, a ferrite bead might be desirable on the cable, to reduce possible resonances.)
Enterprise-grade improvements would include:
- Differential and common mode filtering
- ESD/surge protection (the RS-485 transceiver has excellent ESD ratings, but other interference sources may be a concern, up to and including induced lightning surge on long enough runs)
- A TVS on VCC would be alright, too
- Isolation (very easy to do, a couple optoisolators and a DC-DC converter, adds maybe five bucks to the BOM cost)
Seven Transistor Labs, LLC
The following users thanked this post: Nominal Animal
Offline Rerouter
« Reply #2 on: February 19, 2020, 12:07:45 pm »
It is to reduce fault current if someone hooks things up wrong, still wont save it for voltages higher than 5V, e.g. your connecting up your computer, is there any paths that could cause your DMX bus to sit significantly higher than mains ground voltage? as that voltage will then force a current through that resistor.
Agree with the above recommendations, this is more of a hobby adapter, not really something I would trust for field work.
« Reply #3 on: February 19, 2020, 05:35:36 pm »
I seem to remember bigclivedotcom having something to say on this subject, you might try searching his channel for "DMX".
