Some bench DVMs, such as the -hp- 3456, have a voltage ratio mode, where the display is the ratio between the voltages at two pair of binding posts. In the 3456, there is a limit to the voltage that can appear between the two "Low" terminals.
If I remember correctly, the 3456 does not measure each voltage against its internal reference voltage, but rather measures the ratio by applying one voltage tothe reference of the ADC. Therefore, there is no accurate voltage to be displayed in this mode. I assume the 3458 is similar in that mode.
Thanks, so it is just as i thought.
The application note for the 3458A explains it very badly, i'd even say it's just wrong.
From the application note:
"A “Ratio” measurement performs this same comparison but instead uses a second
measurement of an external reference voltage that is generally known to a much greater
precision"
"The DMM will automatically measure the two applied voltages using internal switching
and then automatically calculate the resulting voltage ratio value from the two
independent measurements. "
It says multiple times that the two voltages are measured and only later compared
