Author Topic: Why two inputs?  (Read 828 times)
Offline viperidae
Why two inputs?
« on: February 07, 2019, 07:26:52 am »
Looking at the datasheet for this bus interface IC, there are two inputs. They're both identical. Why would they do that?
https://www.renesas.com/us/en/doc/products/assp/rej03f0095_ha12240fp.pdf
S1 and S2 are both TX inputs.
Offline vealmike
Re: Why two inputs?
« Reply #1 on: February 07, 2019, 07:45:39 am »
Philosophical rather than electrical your question is. The application must you consider. To see a wood, one must first ignore the trees. Change must come from within, but charge a product of time and current it is.
Yeerrs.
The following users thanked this post: T3sl4co1l, Wimberleytech
Offline viperidae
Re: Why two inputs?
« Reply #2 on: February 07, 2019, 08:01:51 am »
The application for the chip is a physical driver for IEBus, to connect to a NEC/Renesas MCU with a built in IEBus controller.
Those built in controllers only have one TX output.
Online Ice-Tea
    • Freelance Hardware Engineer
Re: Why two inputs?
« Reply #3 on: February 07, 2019, 08:07:04 am »
S1 and S2 are followed by an OR gate. So it allows some sort of multiplexing or logic gating. If you don't need it, tie it to ground.
Offline bsudbrink
Re: Why two inputs?
« Reply #4 on: February 07, 2019, 05:20:11 pm »
Yeerrs.
Stock in Disney/Lucas Arts he owns.
Offline David Hess
  • DavidH
Re: Why two inputs?
« Reply #5 on: February 07, 2019, 07:07:33 pm »
The second input allows the output to be set into a known state without relying on the data source.  This can be especially important when the data source uses a different power domain and may generate spurious data during power up or power down.  The ancient 1488 RS-232 line driver and many other interface ICs have dual inputs also for the same reason.
Offline viperidae
Re: Why two inputs?
« Reply #6 on: February 07, 2019, 09:36:41 pm »
According to the equivalent circuit, these are "active low" inputs, driving the base of a PNP transistor. I think I'll need to tie them together or tie one high.
Online Ice-Tea
Re: Why two inputs?
« Reply #7 on: February 08, 2019, 06:43:24 am »
The DS clearly states that logic high is 2.1V or above.
