Author Topic: Why use a Bypass Capacitor for EACH IC in the circuit?  (Read 15724 times)
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Why use a Bypass Capacitor for EACH IC in the circuit?
« Reply #50 on: September 17, 2014, 08:16:14 am »
What's all that stuff up along the top and bottom sides?  Those look like they need power too!
Seven Transistor Labs, LLC
Offline Falcon69
« Reply #51 on: September 17, 2014, 08:22:48 am »
The throughhole pads on the top and bottom are for the LED assemblies. They have 3 wires for the. Ground, Park, and Brake.  They are connected through the transistors/Mosfets for switching purposes and latching.
The ones on the side are for Left/Right turn signal, Park, and Brake inputs, and the top one is for the main power and ground in.  The very top, where the jump headers are, is so I can connect (if needed) two external Buck/Boost regulators if I cant get the correct voltage to the LED's through the mosfets and transistors.  I am not sure if the battery power from the vehicle is good enough.
But, for this thread, I'm mainly just interested in if the Bypass Capacitors are placed correctly. I tried to put them as close as I could to the power/ground inputs of the IC's.
Offline eetech00
« Reply #52 on: September 18, 2014, 12:31:37 am »
Hi
So....I'm sure others, as well as myself, would like to help but, without making assumptions, how are we supposed to know which pins are power and ground?
Also, as a suggestion, for this kind of board, place a ground pour on both sides to eliminate ground traces and some via's...
eT
