After seeing an EEVblog video about Radioshack's 200-in-1
https://www.youtube.com/watch?v=r1gTu5r8mkQ, I went and bought one on ebay. I may be fifty-some years older than Sagan, but I don't know quiet as much as the kid, so I figured I might learn something.
Anyhow, after a bit of unpacking, I tried my hand at a project, #24 Light Telegraph, as a way to test the kit out. It worked fine for the 6 LEDs, but when I tried it with the lamp, no go. I simplified the circuit to:
Positive terminal 5V -> Lamp -> 100 ohm resistor -> Negative terminal
... nothing, but the LED's would light up.
Then I bypassed the resistor and the lamp lights up nice and bright. I thought I understood the resistance, voltage, current stuff and that the resistor, being tiny wouldn't get in the way of the lamp, but it appears that I was wrong. Thoughts on what's up?
Thanks,
Will
