Author Topic: Is it possible to make one voltage source go two ways?  (Read 6965 times)
Offline TRS-90Topic starter
« on: August 30, 2016, 08:30:29 pm »
I'm trying to figure out how to make one potentiometer control two seperate amplifier chip's volume.
They are not connected to each other.
Is this possible?
PCBF ANALOG BD LC520/LC575/MACTV 820-0582-A, The bane of my existance.
Offline MK14
Re: Is it possible to make one voltage source go two ways?
« Reply #1 on: August 30, 2016, 08:36:32 pm »
One way is to use special potentiometer, called multi gang potentiometers (or dual gang). These are multiple ones which turn together. It saves getting into significant complexity, by trying to use a voltage to control a number of different things. Which can be done, but it can get very complicated, having to use voltage controlled gain stuff.
« Last Edit: August 30, 2016, 08:38:50 pm by MK14 »
Offline Maxlor
« Reply #2 on: August 30, 2016, 08:39:45 pm »
What you need is a ganged potentiometer, something like this: http://www.mouser.ch/ProductDetail/Alpha-Taiwan/RV122F-20-15F-A100K-0072/?qs=sGAEpiMZZMu7u4aXTvZ%252bjx1nJbHWsEkbYq3jcGbMJop5VWZhAcKCRA%3d%3d
They works like 2 potentiometers that are controlled by a single knob, but are otherwise isolated from each other. You can get them in configurations other than 2-gang too, Mouser lists up to 8-gang ones.
« Reply #3 on: August 30, 2016, 08:41:11 pm »
Okay.
I'm just seeing what to do if the thing I'm trying to control only has one voltage coming out to put in to the potentiometer in the first place.
Online wraper
  • Country: lv
« Reply #4 on: August 30, 2016, 08:42:50 pm »
Unless you want to complicate it, you need stereo potentiometer. If you want to use mono potentiometer, as minimum, one additional specialized IC would be required.
« Reply #5 on: August 30, 2016, 08:49:11 pm »
Basically I need a potentiometer with one in and two outs.
one volume voltage, two amplifier chips.
Offline MK14
« Reply #6 on: August 30, 2016, 08:56:50 pm »
What problem are you expecting ?
Are you worried that the signal is too weak ?
Or are you worried that the two amps will fight each other ?
Maybe you are missing many details here, so I can't understand what is going on.
Often a voltage can be split up, as many times as you like. But it depends on the exact details, which I can't seem to find in this thread.
« Reply #7 on: August 30, 2016, 09:01:18 pm »
There is an edge connector that I'm pretty sure has a voltage output on it because two pins are that are next to each other are connected.
I'm assuming that is the only edge connector voltage I will be able to use and I need it for volume control.
This means I have to control two things with one voltage source.
I just don't know how to make two voltage sources out of one, that's all.
Offline MK14
« Reply #8 on: August 30, 2016, 09:05:51 pm »
The two amps. How exactly will you be connecting to them, and what sort of signals/voltages (inputs to them), do we need to control them ?
Most amps, have their own built in potentiometers (volume control or remote control signals), to control themselves. So it is not that easy to control them via an external voltage source. But there are ways of doing it.
EDIT:
Or it might be more practical to attenuate the input signals (adjust their volume), before they enter the amps (but that method may create more stray noise and maybe distortion, depending on your setup). It depends on your exact setup. I still can't really see the overall setup you have/want.
« Last Edit: August 30, 2016, 09:15:51 pm by MK14 »
« Reply #9 on: August 30, 2016, 09:18:37 pm »
The previously mentioned edge connector has pins that go to the volume control on the amps.
The amplifier I dealing with is a TDA7052A-A 1 watt amplifier with DC volume control.
And I just realized that I'm REALLY DUMB,  the both volume control pins are connected to each other.
But how do you split one voltage to go two ways in any situation?
Just for future reference.
Offline MK14
« Reply #10 on: August 30, 2016, 09:32:12 pm »
For future reference.
(Example) If you had a 6 volt battery, so the (output if you like, plus terminal +) voltage was 6 volts from it. You could connect that 6 volt line to as many things as you like, as long as they don't in total, use more amps (current) than the battery is suppose to supply.
Instead of the 6 volt battery, it could have been your volume voltage level signal, etc etc.
« Reply #11 on: August 30, 2016, 09:36:23 pm »
So you  literally just hook up more wires to the source?
I did not think it would be that simple.
Thanks!
Offline MK14
« Reply #12 on: August 30, 2016, 09:37:33 pm »
Thanks!
Yes, it is that simple!
The following users thanked this post: TRS-90
Offline Brumby
« Reply #13 on: August 31, 2016, 04:58:46 am »
Thanks!
Yep.  If they are controlled by a simple DC voltage, it is that simple.
If you were directly controlling the audio signal itself, however, then you would be back into the problem area (but one that is easily solved)
Online Zero999
  • 0999
« Reply #14 on: August 31, 2016, 08:43:35 am »
The TDA7052A looks like a nice IC. It's a shame only the SOIC package sill seems to be made which has a power output of 0.5W, rather than 1W of the DIL package.
Yes, the gain control inputs can simply be connected together and the voltage to them both varied.
« Reply #15 on: September 05, 2016, 09:49:18 pm »
I now have another small problem.
How do I combine to signals from two separate wires to one wire that carries both?
Something that normally uses two separate signals on two separate pins use the both on one (i.e. a TV using horizontal and vertical sync on one wire of a special connector instead of two).
Is it as simple as hooking the wires together?  Or is it more complicated?
Online Zero999
  • 0999
« Reply #16 on: September 05, 2016, 10:17:50 pm »
You need a mixer, which can be passive (just resistors) or active.
In a passive mixer there's always some voltage loss: a minimum equal to the number of signals combined, so for two you're looking at half the voltage.
In an active mixer an amplifier is required so there can be voltage gain but a separate power supply, other than the signals is required.
« Reply #17 on: September 05, 2016, 10:30:50 pm »
Well what I'm dealing with is a CRT monitor I'm trying to solder wires to (it has a proprietary edge connector) and there is a pin labled "composite signal" not composite video signal just composite signal and there are no HSYNC or VSYNC connectors on the board.
How do you make a passive mixer?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #18 on: September 06, 2016, 04:28:26 am »
If I might gently bring this to your attention, :)
http://xyproblem.info/
Please, for your own sake, and for the sake of our sanity...  tell us what you want to do, first! ;)
Seven Transistor Labs, LLC
Offline Brumby
« Reply #19 on: September 06, 2016, 05:04:04 am »
If you see a pin labelled...
"composite signal"
"composite video signal"
"composite video"
- or even just "composite" on a piece of equipment that obviously processes a video signal
... then you will be dealing with the same thing.
But this is, perhaps, THE most important recommendation I would support:
The specifics of your answer to this will allow us to give you more direct assistance.  Otherwise we are just guessing - which can add a lot of frustration and confusion ... on both sides.
« Reply #20 on: October 21, 2016, 11:09:41 pm »
I need to make HSYNC and VSYNC into CSYNC for a monitor.
My video source has  seperate sync, my receiver has composite sync.
Monitor has vey little information available on it.
Offline basinstreetdesign
« Reply #21 on: October 23, 2016, 05:03:30 am »
If you have an output that says "Composite" or "Composite video" then CSYNC is included in that composite video.  If you want composite sync with video then just using that output may be all you need.
However, if you need just a CSYNC signal, which has no video included then combining VSYNC and HSYNC is NOT a trivial exercise.  It requires some involved logic and timing circuitry to get it right.  That circuit will also be different depending on whether the video in question is NTSC, PAL, or analog HDTV or what.
Just putting the two through an XOR gate and inverting the output and using that may get you close but it still will not be correct and the resulting picture will have bends and wonks in it but if all you want to do is get an idea of the picture it may be good enough in the short term.
STAND BACK!  I'm going to try SCIENCE!
