Author Topic: For testing spec OP AMP, can i use this circuit ?  (Read 2601 times)
Offline ammjyTopic starter
  • Country: kr
« on: March 10, 2017, 08:26:38 am »
Hello !
i don't know about OP AMP well. but, for my project i buyed low noise op amp OP37G.
but, i don't know it's fake or not fake. so i want check my op amp via input bias current.
Please, see screenshot picture. can i use this circuit for checking spec OP37G ?
i have EEVBlog ucurrent.
in datasheet, input bias current is typical ±15 nA, Maximum ±80 nA.
and checking via input bias current is good method ?
i want check via offset voltage. but, my oscilloscope resolution is just 2mV with Bandwith limit. i don't have idea.\
Please, let me know. Please, i need help.
« Last Edit: March 10, 2017, 08:32:09 am by ammjy »
Online Zero999
  • 0999
Re: For testing spec OP AMP, can i use this circuit ?
« Reply #1 on: March 10, 2017, 08:47:24 am »
You should use higher resistor values than that to measure the bias current.
Why are you using an oscilloscope to measure the offset current? It's the wrong tool for the job. You need a volt meter to measure DC voltages.
The following users thanked this post: ammjy
  • Country: kr
« Reply #2 on: March 10, 2017, 08:54:02 am »
Thanks you.
i mistake wrote, Sorry. i always in tension.....
i will use my multimeter and ucurrent. but, multimeter can't measure nV range. ucurrent is for currunt measure.
without any input, just with x1000 feedback circuit, can i measure offset voltage ? +/- 15~80 nV ?
Offline danadak
« Reply #3 on: March 10, 2017, 12:40:05 pm »
From one of the gurus of our time -
https://www.ti.com/ww/en/bobpease/assets/www-national-com_rap.pdf
Pick the article "What's All This Femtoampere Stuff, Anyhow?" and "What's All This Teflon Stuff, Anyhow?"
Regards, Dana.
« Last Edit: March 10, 2017, 12:46:24 pm by danadak »
Offline b_force
    • One World Concepts
« Reply #4 on: March 10, 2017, 02:41:23 pm »
That really depends on the type of scope and multimeter.
I know enough scopes that are much more accurate than some multimeters.
Online Zero999
  • 0999
« Reply #5 on: March 10, 2017, 03:00:17 pm »
Thanks you.
It depends on the accuracy of the multimeter. You may need to increase the gain further.
They must be pretty poor multimeterss.
  • Country: kr
« Reply #6 on: March 10, 2017, 04:13:51 pm »
Regards, Dana.
Thanks you teach me.
I'll not forgot your help. Thanks !
  • Country: kr
« Reply #7 on: March 10, 2017, 04:15:52 pm »
Thanks you.
Thanks you, your advice.
i'll not forgot your help ! ill try !
  • Country: kr
« Reply #8 on: March 10, 2017, 04:17:33 pm »
Thanks you comment !
today, i studied via you.
