Hi everyone,
some time ago I got a "Smart Car" kit very much like this:
https://www.amazon.com/SunFounder-Arduino-Obstacle-Avoiding-Tracing/dp/B01DU3TKPY (this one is not exactly the same car, but same manufacturer, I cannot link to their webpage at the moment)
The car is powered by two 18650 cells in series, that are not included in the kit. Regardless of the very "chinglish" manual, there is one thing in the manual that I found strange: It explicitly requires the use of unprotected cells. I remember that this was also listed on the amazon product page back when I bought it, but that page is not available anymore.
The batteries are directly connected (via a switch) to a regulator module that outputs 5 volt. As far as I can see, there is no battery protection inherent in that module, and the batteries have to be externally charged anyway. If you want, I can test the unloaded dropout voltage of the regulator module.
I am currently using two protected cells and everything I tested so far works as expected. I have read a lot about lithium batteries, I'm sure a lot of it is scare-mongering, but I still would not want to use unprotected cells in a device that is not protecting them against deep discharge.
What could be the reason to require unprotected cells?
I can think of two things:
- protected cells are slightly longer, and might not fit the battery holder. Indeed the cells I am using now are a very tight fit, but the kit even contains two ribbons that can be threaded under the batteries to easily remove them from the holder.
- the protection might kick in if high current is drawn, which in turn might cause the user to think that the kit is busted. I do not have the kit fully working yet, so I was not able to test the current draw.
Any thoughts?
