Author Topic: Why would I use a "Resistive Touchscreen Controller"  (Read 1395 times)
Offline michaelym
« on: December 18, 2013, 07:07:30 am »
Why can't I just use the ADC in my MCU?
Offline tesla500
Re: Why would I use a "Resistive Touchscreen Controller"
« Reply #1 on: December 18, 2013, 07:42:46 am »
It provides some nice features like current limiting drivers, for the case where you touch both the top left and bottom right (for example) of the screen and the touchscreen effectively becomes a short circuit. Also, touchscreens are often used in systems with high end microprocessors that don't have any internal ADCs.
Offline con-f-use
  • Country: at
« Reply #2 on: December 18, 2013, 09:31:24 am »
And some are protected against static...
Offline lapm
« Reply #3 on: December 18, 2013, 11:55:23 am »
My limited experience on capasitive and resistive touchpads is that resistive ones are more accurate. but this just mo opinion, have not done any testing other then couple mobile phones...
As others have pointed out, dedicated interface chip on these usually provides some handy features that are good to have.
Want to be super cheap, nothing is preventing you to use MCU's AD converter, but then you can expect some troubles to show up. Things you might not know that touchpad can do or behave like that...
Electronics, Linux, Programming, Science... im interested all of it...
