Hi Folks,
A few months ago I came across some info online about BEAM robotics (Biology, Electronics, Aesthetics, Mechanics) and all of the fun everyone was having back in the 90's. Being somewhat of a newbie to electronics I set out to learn more by working with several of these circuits. My latest attempts have been with a simple "pummer" but I continue to hit a wall and cannot seem to get past it. It's a very basic circuit. A 74AC240 octal inverter, a few caps, LED and a solar panel. It's intended to charge the NiMH batteries during the day and discharge them through a blinking LED at night.
The thing is while I've gotten it to work, it ONLY works when the smaller capacitors that are tied to the opposite outputs are different values. This is at odds with all of the schematics I've ever seen published for this design. It doesn't really matter what the caps are in my build as long as they aren't the same. I can't for the life of me get the circuit to work when the values are identical (0.22uF) as called for in the design. It's driving me crazy!
I've tried rebuilding the circuit numerous times, tried another IC, different cap values, different locations on my breadboard, another breadboard, etc. It works which I guess is great but infuriatingly so, blinking away as it oscillates back and forth all the while mocking me by not working the way it should.
Is there something I'm missing here? Is there a flaw in the design or am I just not understanding properly what should be happening? I'm using a legit TI inverter and all my components seem to be fine. I'm just not getting the expected behavior when I follow the schematic.
Here's the schematic I'm using:
I've found other versions of this online (including a more illustrative one in Make Magazine) and they all appear to be the same.
Any thoughts?
