Author Topic: Wi-Fi router power output  (Read 964 times)
Offline Jane
« on: December 09, 2017, 09:24:35 pm »
What methods can be used for measuring the power output of a Wi-Fi router?
Is it also possible to measure  the waveform of that wifi router( antenna power signals)?
Thanks for suggestions
Offline danadak
Re: Wi-Fi router power output
« Reply #1 on: December 09, 2017, 10:16:43 pm »
A spectrum or network analyzer. Or a calibrated antenna, like a dipole or monopole.
Yes, there are scopes that can actually see the waveform. Sampling scopes would permit
that. Its complex modulation, DSSS, so you could look at the modulating signal or the complex
carrier result.
https://en.wikipedia.org/wiki/Direct-sequence_spread_spectrum
Regards, Dana.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: December 09, 2017, 10:45:22 pm »
Something like this would also work very well.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline Jane
« Reply #3 on: December 11, 2017, 09:06:23 am »
@danadak: You say
do you mean to connect an antenna to a spectrum analyzer? Or to use an antenna with a different device such as a scope?
And what kind of scope to use?
Thanks
Offline danadak
« Reply #4 on: December 11, 2017, 11:18:13 am »
Online Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #5 on: December 12, 2017, 04:05:09 pm »
 There are some diy network analyzer based on esp chips, on instructables
Offline Azu
« Reply #6 on: December 19, 2017, 01:21:05 am »
Surprisingly, the Wifi Analyzer app on the Play Store does a pretty pretty good job at measuring your signal vs competing signal in your area best of all it's free! I assume if you're a Apple user they should have something equivalent.
