Why not an Wifi Repeater?
Because people usually fly drones outside and don't want to set up a range extender out in the bush on a giant extension cord?
(Ok, it could possibly be battery powered.)
Anyway... it's not what royderuyter was asking for. Of course there is a polarity issue. You solder the shield to ground and the center connector to the antenna signal. Isn't it clear enough from this video
Are you asking how to solder in general? How to cut and strip the coax? Which pad is ground and which is the antenna, or what?
