Not sure where this question belongs, but I am working on a portable pneumatics project. Trying to figure out the best design approach when speccing out the compressor.
This compressor fits our functional and sizing needs.
VIAIR 350C
- 12V dc
- 20A
- ~.5 CFM (@max pressure)
- 100% duty @ 100psi
- 9”L x 4”W x 6.75H”
But our problem is powering it properly. I lack a complete understanding of my power supply specs. So this is where my post splits in two directions:
Q1) Can I find a similar (price/size/power) compressor that accepts 120VAC? I have tried looking around... alibaba, google, etc. I don't exactly know of a place to search for "small 120VAC compressors"
Q2) If I cannot go the AC route, what do I need to look out for on my power supply to make sure I don't cause early failure?
EXAMPLE: We have tested with a
PUB250-12 power supply (output 12V ~21A). This PS can turn on the compressor, but it dips down to .5V while supplying the inrush current. I am assuming this arrangement isn't sustainable for longterm use (see attached image: Vout from power supply as compressor starts up).
What risk am I running with this power supply? What would I need to change or design to mitigate that risk? Should I implement IRC limiting, or do you think it would be cheaper to get a larger supply?
All thoughts welcome. Thanks in advance.
