Author Topic: Good Fume Extractor for Dorm Room  (Read 7767 times)
Offline ciikucli
« on: October 12, 2012, 10:25:06 pm »
I'm going to be doing a bunch of soldering in my dorm room, and the ventilation is somewhat limited. Can anyone recommend a good fume extractor? I see the Hakko FA400 and the Zephyrtronics ZT-4. I've also heard things about PACE, but they're quite a bit more expensive. Thank you!
Offline ablacon64
  • Country: br
Re: Good Fume Extractor for Dorm Room
« Reply #1 on: October 13, 2012, 12:16:54 am »
How about a DIY solution? http://www.instructables.com/id/DIY-Fume-Extractor/?ALLSTEPS
I can be very effective if you use a good carbon filter.
Offline george graves
« Reply #2 on: October 13, 2012, 03:08:27 am »
On a budget?  I'd get a small fan, and some dryer hook up kit (or just the tubing) and some duct tape.
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #3 on: October 13, 2012, 09:30:51 am »
Depends on your budget. The cheapest will be as George said: A fan and tube out the window; no doubt that will work just fine. Next step up could be:
Hand soldering:  http://www.techgsm.org.uk/Smoke_Absorber_Fan_486,5801.html. I have one, and it is surprisingly effective for hand soldering work. Very good value for the small money. I bet you can get this in US, too.
SMD assembly using skillet or pizza oven method: a kitchen hood unit. A desktop filter is far from enough for this job. Don't even try these methods in a dorm without a hood with a duct to outside, the smell will be awful. I live in a house, and the whole house needed windows open after my first oven assembly, wife  >:(. Fortunately, the stink didn't stick. Before the next board, I will have  an Ikea 39€ unit over the oven with a duct out to window.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #4 on: October 13, 2012, 10:07:43 am »
I'm making one at the moent and using a fan out of an extractor unit.
no one would or will tell me how to delete this account
Offline AndyC_772
« Reply #5 on: October 13, 2012, 12:19:07 pm »
IMHO the best thing to do, especially if you're only soldering occasionally and won't be breathing in the fumes on a regular basis anyway, is to simply avoid generating anything too harmful in the first place.
Avoid colophony / rosin based fluxes and you may not need extraction at all.
Offline Jimmy the Squid
  • Complete and utter newb.
Re: Re: Good Fume Extractor for Dorm Room
« Reply #6 on: October 13, 2012, 01:53:16 pm »
That extractor is gorgeous! I think I'll add that to list of stuff to build. Too bad the parts cost more than just buying an extractor. Maybe one could substitute an old ATX power supply box for the $30 Hammond box. Of course it would never look as good.
Offline prenato
    • paulorenato.com
« Reply #7 on: October 13, 2012, 02:30:56 pm »
That's funny you mention that because that's exactly what I have done. Painted black doesn,t look too bad. Check it out:
http://paulorenato.com/joomla/index.php?option=com_content&view=article&id=84:fume-extractor&catid=4:projects&Itemid=4
Paulo
Professional Tinkerer,
www.paulorenato.com
Offline M0BSW
« Reply #8 on: October 13, 2012, 03:22:55 pm »
well done this would look in any lab/workshop/place to escape wife
Offline ablacon64
  • Country: br
« Reply #9 on: October 13, 2012, 03:56:58 pm »
I know but it kicks! I'm almost done with the parts to build one!  :)
Offline ciikucli
« Reply #10 on: October 13, 2012, 06:07:32 pm »
I like the DIY one, and I can stick in a HEPA filter for extra protection. IT sure is pretty.
Offline mariush
« Reply #11 on: October 13, 2012, 06:39:26 pm »
If you're not so found of making one from spare parts, you might wanna think about a car vacuum cleaner or something similar.
For example: http://www.amazon.com/Eureka-71B-Hand-Held-Vacuum/dp/B0006HUYGM/ref=sr_1_2?ie=UTF8&qid=1350153369&sr=8-2&keywords=car+vacuum+cleaner
Offline ElektroQuark
    • ElektroQuark
« Reply #12 on: October 13, 2012, 07:17:52 pm »
Too much noise.
Re: Re: Re: Good Fume Extractor for Dorm Room
« Reply #13 on: October 13, 2012, 09:02:43 pm »
Very well done. Adding it to he base of a bright lamp is another stroke of genius!
Offline ablacon64
  • Country: br
« Reply #14 on: October 13, 2012, 09:16:59 pm »
I like that also, how about joining the beauty of the first with that functionality?
Offline prenato
    • paulorenato.com
« Reply #15 on: October 13, 2012, 10:25:08 pm »
Thanks Jimmy. It's working well for me so far:)
Paulo
www.paulorenato.com
Offline Mediarocker
  • If it ain't broke, open it anyway!
« Reply #16 on: October 14, 2012, 10:54:17 am »
Matter of fact, I just am about finished building mine. Cost me about 30 bucks for all the parts, and All I have to finish is the filter funnel.
I'll post up about later when I get off work. :)
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
« Reply #17 on: October 14, 2012, 12:02:40 pm »
Superb ,
       Can you shed more light on the base  ? .what was the original thingii
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
Offline prenato
    • paulorenato.com
« Reply #18 on: October 14, 2012, 01:44:48 pm »
This was an halogen lamp so the base already has a pretty heavy 12 V transformer.
I added a bridge rectifier to convert it to "DC" for the fan.
Paulo
www.paulorenato.com
« Reply #19 on: October 14, 2012, 11:22:28 pm »
halogen lamps are 12v AC(not DC)?  Didn't know that if that is correct!
Offline prenato
    • paulorenato.com
« Reply #20 on: October 15, 2012, 12:10:54 am »
At least the ones commonly found in these small desk lamps are 12 V AC. For example:
http://www.amazon.com/gp/aw/d/B00589YKA4
Paulo
www.paulorenato.com
