Hello there,
I am making a switch mode power supply. I am finding it challenging. It has a LM25116 buck controlled by PWM from a PIC18F4550.
I understand from the datasheet of the LM25116, that a voltage higher or lower than 1.215V on the FB pin alters the the duty cycle of the buck either up or down. As a result Vout is altered.
I thought that the best way control this by MCU was to use an op-amp with Unity Gain Differential Amplifier configuration where I input 1.5-4.2 voltage to correspond to Vout of 1.5-4.2. The inverting input has to be 1.215 lower than the non-inverting: f(Vout) = .199 * Vout.
I just wonder if my solution is good, or if it can be improved. I find at least one problem. But I am not sure how to solve it. I mostly need help with the feedback circuit inside the blue ellipse at the moment. The rest of the circuit is nowhere near completion.
Any critique is much appreciated. When I listed to Dave talk about his design, I am often surprised about things that I did not know.
Thank you very much for your time!
Kind regards,
Marius
PS: This is the LM25116 datasheet. On page 13, the Error Amplifier is discussed.
http://www.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=snvs509c&fileType=pdf
