I think I may have solved my problem.
When I shorted D+ and D- togeather on the USB side of my adapter while charging my phone, it yielded these results:
+4.83 Volts @ 0.98 Amps
...image snipped...
My only concern is, does that V-droop indicates something could go wrong.
Also, I see the concern about my battery bank. I figured those 18650s wouldn't heat up then explode by themselves because of such a low current draw between them, but in the case that some freak accident occurs such as the regulator being cheap and could be broken by an external power source that has a huge spike in power...FYI I got the batteries from "DELL"
Yup! Actually almost 1A is not too bad. That is why I described my Kindle-2A charger voltage dip problem. The voltage was dropping below what the USB-charge-port needs to draw more current. I found most power-bricks will dip quite a bit. That is also the reason why I was seriously doubting that you can draw close to 1.5A.
As long as your power-brick is holding out, it should do ok. BUT since it dips that much, I would not rule out that after a while, it could freak out.
Who knows what it may do when it freaks out so surly there is no guarantee. Spend some time with it while it runs. Touch and see if anything is getting too hot to touch/hold. Run it for a couple of days to see if you are comfortable using it.
This is a good time to have a dummy-load. I have a dummy load (home made, +-5%) that I can log to PC to make myself comfortable with the connection and the power source capability.
re: "Also, I see the concern about my battery bank. I figured those 18650s wouldn't heat up then explode by themselves because of such a low current draw between them."Yeah, may be. Charging 12x18650 with 1A is
not going to get it too hot if things are going right - but what if something goes wrong?
- (self-developed internal short due to battery way out of shape) If you look at the other thread I linked to, I described a playing around with my old (10+ year old) StarTac sub-1000mAH battery which all a sudden went hot by itself. Since I was playing with it, I do not rule out it was my dumb mistake instead of it being a purely self-developed short. Whatever it was, it went hot. Say if one of your battery starts to go, you have 11 other battery shorted by it. Poof! Fireworks!
- (old battery too out of shape) I have some recovered 18650 that after charging to near 4.0V (not yet full, obviously), it stops charging and turns the incoming current into a heat. If I did not have a temperature monitoring charge process, I could be crispy to very-crispy later that evening.
- How good/bad is the charger you are using? I am referring to the one that goes from your +5V input to the batteries. What if something goes wrong there and it tries to charge the batteries at 4.5V or even 4.8V? (ie: your charger voltage regulation died and just pass the 4.8V along directly to the batteries.)
A boat load of little things can happen.
If you use a good 18650 charger, charge them individually, and power-bank each battery as 12 separate 1x18650 power-banks, the damage is limited. When you have 12 in one pack, just one of them going south could make the whole pack go with it...
Call me Chicken - I am probably too conservative. In my view, life is risky enough without adding unnecessary risks.
