Thank you! Why is there the option to disable OCP/OVP?
A rebadged Korad. A kind of manual is at http://sra-solder.com/shopimages/products/instructions/KARAD%20user%20manual-multiple%20channel%20power%20supplies.pdf
OK, I get that for OCP, i dial in the max amps I want to be pulled and can bypass this with the button............But, how does that work with voltage? how could something pull more voltage then I have dialed in on the PSU?
