I have seen another question on transformers in the general chat section and as I want to build a transformer too (with both primary and secondary coils) I would like to ask my questions about transformers.
Somebody on youtube describes how to wind a low current transformer, here:
There are a few points I do not understand: At the end of the video when he tests the transformer with a series circuit, he shorts the secondary and the bulb lights up, but normally the transformer with an open secondary too has a quite low primary coil resistance, hasn't it? Therefore I don't quite understand why there is not enough current in that series circuit on the primary to make the bulb light up...
When the secondary is open circuit,the primary impedance is high,so there isn't enough current to light the bulb.
(If this didn't happen,& a transformer primary just looked like its DC resistance,it would short out the mains)
When he shorts the secondary,the primary impedance falls so the bulb lights.
Besides that between 9'28" and 9'35" he interchanges the edges of the coils to form the central tap. If he does not do that I guess both 18 volt rails will have the same phase right? The fact of interchanging is to have an 180 degrees phase difference or ...?
To get an isolated ground reference, can we just use an adapter without a ground connector to plug a device to the mains? Would this be equivalent to using an isolation transformer?
NO!!!!! The mains neutral & the house earth are connected together,either at the mains entry point,(usual),or at some point in the mains system.
In turn, the earth connection is normally connected to the metal case or chassis of the device,so in the case of a fault which connects the Active wire to this case,the fuse will blow.
If you remove the earth,you remove this protection,& if the same thing happens you can get a shock between the case & any other earthed object.
By adapter, I meant an adaptor plug like A, B or C type on the following page:
http://www.american-allergy-supply.com/dn3000/foreign-adapter.htm
Traditionally,a transformer has been used as part of a device to supply the various voltages required for it to operate,with the only wiring directly connected to the mains being fairly simple connections to the on/off switch & hence the transformer primary.
Working on such equipment does not normally require an additional isolation transformer.
Switchmode power supplies,on the other hand,have quite complex circuitry which has a common main connection.
It is good practice to use an isolation transformer with such devices,especially if you need to look at switching waveforms,as Oscilloscopes normally have one side of their circuitry connected to earth.
If you place the earth clip of your 'scope probe on the active side of the mains,you will see a blinding flash,& probably do your 'scope & possibly yourself an injury!
Ok I think I get it now (or do I?). If we use that adaptor, as the mains earth is usually connected to the neutral, there would still be a "galvanic" connection between the earth and the neutral, whereas with the isolation transformer, this wouldn't be case.
By George! I think you've got it!
Yep! Without the isolation transformer,one side of the supply to the switchmode or whatever, is connected to the Earth.Most of the plumbing in the house,& the outside cases/chassis of the other electrical/electronic equipment are also connected to earth to provide the safety function previously discussed.
If you use an isolation transformer,both sides are above earth,so there is no voltage between earth & either side of the supply to the device under test.
If you really try hard,you can still get zapped,but you have to hang across both sides of the isolation transformer secondary,which is fairly hard to do accidentally.
Don't kid yourself that because the neutral is theoretically at the same potential as earth,you can connect the earth clip of your 'scope to that point.
DON'T DO THIS!,as you may have a reversed socket or plug,& you will again zap yourself or your scope!
