Hello,
I'm trying to play with small sparks and was tinkering around with few circuits.
I was trying to achieve sparks with a single pulse similar to a ignition coil. I was wondering what determines the size(core area) of a ignition coil for single pulse sparks.
I started with a small ferrite toroid 10mm in diameter and wound few turns in primary and 200 odd turns in the secondary, and discharged a capacitor in the primary, the capacitor was charged to 30 volts, since the turns ratio was 60:1 i expected around 1.5 to 2Kv in the output, but I couldn't see any spark.
The primary ohms was around a few milliohms and the secondary was around 20ohms, the gap that I kept was around 0.4 mm keeping in mind that air has a 3KV /mm breakdown.
I'm wondering why this didn't work, is the transformer not producing the desired voltage or is there any definitive calculation for core area or any rough way to estimate the minimum core area required, mine was a small toroid cross section area of 8mm2.
