Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
50 Ohm output
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 50 Ohm output (Read 3374 times)
Flump
Frequent Contributor
Country:
50 Ohm output
on:
March 25, 2014, 05:49:32 pm »
Hi All
I want to try measuring ESR using my scope like Alan does here
But i dont have a proper function generator so i bought one of these
http://www.ebay.co.uk/itm/350945193079?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
but there are 2 problems i see which are it's not 50 Ohms output and the output voltage will be too high,
do i just add a VR in series of the output to drop the voltage down ?
and how to i make the output 50 Ohm ?
Logged
michaelym
Regular Contributor
Re: 50 Ohm output
Reply #1 on:
March 25, 2014, 08:35:04 pm »
The output does't have to be 50 ohms. As long as you have a known output impedance you are OK.
You can just measure your output impedance, it just cant be too high.
Logged
Zero999
Super Contributor
Country:
0999
Re: 50 Ohm output
Reply #2 on:
March 25, 2014, 08:36:47 pm »
A 555 timer has a fairly low output impedance. Connect a resistor, say 100R in series with the output and adjust the calculations to suit.
Logged
Flump
Country:
Re: 50 Ohm output
Reply #3 on:
March 25, 2014, 08:46:59 pm »
thanks very much guys will try it
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
50 Ohm output
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
