Info requested by user bdunham7 in my intro post
https://www.eevblog.com/forum/beginners/new-user-introductioninterest-feeler/Quoting bdunham7:
"I can probably help, but I'd need to know what year/model the new steering column came from"
The steering column and switch are from a 2001 Chevy pickup. The switch is a AC Delco part number D6257C, GM # 26100839. This is the schematic of the wiper/washer system:
8-485 Schematic-Wiper Washer Switch.pdf (495.66 kB - downloaded 127 times.)
EDIT: I did something wrong, the attachment is at the end of the message.
Again quoting bdunham7:
"as well as the technical details on the replacement wiper motor."
This is the wiring diagram for the new motor. That is the standard two speed switch that comes with the motor. The off position of the switch supplies 12 volts to the park terminal which operates the motor until the wipers return to the park position.
"The solution may be as easy as taking apart the wiper motor assembly from the steering column donor and extracting the control module circuitry."
Great minds think alike! That was my first thought and the first thing I tried.
I have the wiper motor module (GMs term for the motor with attached circuit board) from the same truck as the column and switch. I have tried to use just the circuit board (without the motor) wired to the switch as in the original vehicle. The circuit board has three terminals that plug into the motor. Bench testing shows them to be GROUND, HI speed and LO speed. I then wired the HI and LO speed outputs to relays to control the new motor. I do not yet have the new motor so used 12V bulbs to monitor the outputs, including one for the PARK circuit. HI and LO speed switch positions come on as expected. All delay positions will activate the LO speed. The problem is the circuit board is half of the park switch. The other half is a rotating contact on the motor that turns the motor off in the correct park position. Without those two halves together the motor LO terminal on the circuit board has 12V for appx. 6-10 seconds after the switch is in the off position. My guess is a timer on the board takes over. This is too much time to wait for wipers to go off and park. If this board could be modified to eliminate that delay to off, that would be my preferred solution.
Next I soldered a wire to the LO speed output of the board and ran it through a hole in the board housing so I could reassemble it and have access to the LO speed output. HI speed is a direct board trace from the HI speed switch wire to the HI speed terminal, so no extra wire needed. I wired all this up to my mock up relays and bulbs and everything worked as expected. With the internal park switch now working power is restored to the PARK circuit for the new motor any time the switch is off. For this to work in the car I would have two wiper motors, one doing switching duty and the other working the wipers. It would work but seems a really crude solution.
This is the diagram of that setup, except I used three bulbs where the new motor is shown.
