I would interpret it as:
Two conductors, each consisting of 14 strands of 0.12mm diameter wire.*
0.12mm = 0.0113mm^2
14*0.0113 = 0.158mm^2 = 25AWG
If that’s correct, I wouldn’t be chasing a lot of current through it. :/
As for the second one, similar math:
10 strands of 0.12mm diameter = 10*0.0113mm^2 = 0.113mm^2 = 26-27AWG
28 strands of 0.12mm diameter = 28*0.0113mm^2 = 0.316mm^2 = 22AWG
I’m assuming that despite the photo, it’s a coaxial wire, which would explain why one conductor is so much beefier than the other.
In a nutshell, both of those are really, really thin cables...
*Despite the fact that in metric, wire is normally given in cross-section, not diameter, but 14*0.12mm^2=1.68mm^2 would be fairly hefty wire, about 15AWG, probably too thick for those plugs. And moreover, the outer diameter of the wire is specified at 1.8mm, and the diameter of 1.68mm^2 solid wire would be 1.5mm, leaving only 0.3mm for insulation — and this is stranded, which will be fatter.
(Really, eevblog doesn’t support the almost-equals sign, either? I wish they’d join the 20th century and update to Unicode...)
