Author Topic: DIP alternative for TL071??  (Read 4042 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: March 07, 2017, 03:25:37 pm »
Is there a DIP package alternative to the SMD JFET input general purpose Op Amp type TL071 available that would be electrically identical please?
The info on the TL071 is available here: http://www.ti.com/product/TL071
Thank you.
Best regards,
                 Chris Wilson.
Offline Lightages
  • Canadian po
Re: DIP alternative for TL071??
« Reply #1 on: March 07, 2017, 03:33:29 pm »
You need to be a bit more forthcoming on what the use is. There is no exact equivalent but many that can do the same job or better but it depends on the circuit it is being used in. Is it a general audio buffer or preamp or......  what?
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #2 on: March 07, 2017, 03:50:59 pm »
Thank you.
Hmm... TL071 is available in a DIP package, so what is the problem?
Cheers
Alex
« Reply #3 on: March 07, 2017, 03:51:33 pm »
Here's the relevant bit of the schematic I wish to build and use separately, thanks. It's outlined in red.
Best regards,
                 Chris Wilson.
« Reply #4 on: March 07, 2017, 03:53:26 pm »
Maybe I am using the wrong terminology, I want a similar device that can be socketed?
Best regards,
                 Chris Wilson.
Online Alex Nikitin
    • A.N.T. Audio
« Reply #6 on: March 07, 2017, 03:57:12 pm »
Yes, the PDIP package version of TL071 can be socketed. Look at the web page for the TL071 you've linked - at the bottom there is list of packages available, including PDIP. Here is a link to Farnell page on it.
Cheers
Alex
« Reply #7 on: March 07, 2017, 03:58:11 pm »
http://uk.farnell.com/webapp/wcs/stores/servlet/Search?catalogId=15001&langId=371&storeId=10166&st=TL071&selectedCategoryId=%5BLjava.lang.String%3B%401b761b76&showResults=true&pf=110132318
Thank you, I will flagellate myself severely, I looked at the data sheet and saw no image of what I wanted so assumed it was only available in surface mount, my apologies! Thank you for the link wraper and Alex!!
Best regards,
                 Chris Wilson.
Offline CJay
« Reply #8 on: March 07, 2017, 06:30:03 pm »
As it happens I was stripping an old piece of kit today and...
*wanders in and drops this just here*
« Reply #9 on: March 07, 2017, 07:48:04 pm »
All right, all right, no need to rub it in ;) I believe, I believe! :)
Best regards,
                 Chris Wilson.
Offline CJay
« Reply #10 on: March 07, 2017, 08:12:58 pm »
 Sorry, just couldn't resist the coincidence ;)
(If it's useful I think Maplin stock them?)
« Reply #11 on: March 07, 2017, 08:18:39 pm »
Thanks for that CJay, Maplin is a long drive, with me being out in the sticks, so I have ordered from RS and will let the postal service do their bit. Appreciate the tip though!
Best regards,
                 Chris Wilson.
Offline Kleinstein
« Reply #12 on: March 07, 2017, 08:43:12 pm »
Chances are the TL071 once was DIP only - when it was new, there was not much SMD.
Offline james_s
« Reply #13 on: March 07, 2017, 08:50:04 pm »
I'm fairly sure it was. I don't recall when SMT ICs started showing up but I have some boards that are over 35 years old that have DIP package TL071's and TL082's on them. Those are fairly ubiquitous parts that have been around for a very long time.
Offline Messtechniker
« Reply #14 on: March 07, 2017, 09:41:31 pm »
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
