Author Topic: wire to wire type connector for small dc motors  (Read 1666 times)
Offline charlesTopic starter
« on: August 21, 2014, 05:00:11 pm »
Hello,
I have 4 small dc motors, take <400 mA each, that I want to connect to my circuit board. Thus, I have 8 wires that I need to hook up to the board. I was thinking the best thing would be to run 8 wires from the circuit board to some kind of 8 pin female type connector and then have the 8 wires from the motors be attached to the corresponding 8 pin male connector. I went on Digikey but was quickly overwhelmed. I thought that something like this would be appropriate:
http://www.digikey.com/product-detail/en/794954-8/A30593-ND/701598
and
http://www.digikey.com/product-detail/en/794953-8/A30581-ND/701586
But then I couldn't figure out how you are supposed to attach the cables to the connector; I noticed it says "Contacts Not Provided".
Does anyone have suggestions on how these connectors are fitted to the wires and/or other good/better connectors for doing this?
Offline wyphy
Re: wire to wire type connector for small dc motors
« Reply #1 on: August 21, 2014, 06:18:42 pm »
Those look like they use pins very similar, if not identical, to those used in computer power supplies.
You just have to find the pins on your supplier site; they probably come 100 to a bag for $3.00 or something.
They are either crimp or solder, and you just put the pins on the wires, then insert all the pins into the connector.
Offline Kremmen
« Reply #2 on: August 21, 2014, 06:32:33 pm »
Check the Digikey product pages you linked. Towards the end you will find a list of "Associated products". Those are the pins that go into each slot. Connections by crimping or soldering just as wyphy said.
Nothing sings like a kilovolt.
Dr W. Bishop
