Author Topic: Wireless mains remote master / slave switch module, where do I find one?  (Read 1382 times)
Offline alcs2000auTopic starter
Hi guys
I am trying to turn on some lights somewhere else in the house if the main lightswitch is turned on. Hence I am looking for a transmitter watching the status of the main light switch to then also set the receiver relay module the same way. Basically a remote wall switch with the wall switch replaced by a transmitter monitoring the preinstalled one.
http://www.gentec.ca/eng/products/active-circuit-transmitter.asp
I think this does what I am looking for, I am however looking for the correct name of this module as well as If there is anything like this on digikey or mouser that I can actually order.
Thanks!
« Last Edit: April 20, 2019, 08:42:32 pm by alcs2000au »
Offline chagli
The complete name seems to be ERM-DAU-277.
I don't think you will find this kind of specialized module on Digikey.
It could be a funny project though.
Online rstofer
Alright, I thought this was a standard product. If I have to do it myself I think ill do it with Sonoff and Tasmota. Thanks for the inputs! Wish there was a standard off the shelf solution out there that can easily be purchased...
« Last Edit: April 21, 2019, 08:09:04 pm by alcs2000au »
Offline soldar
The requirements are a bit vague but it sounds like signalling over the powerline might be the way to go.
