Author Topic: Wireless transmit large data/low power  (Read 1437 times)
Offline A2Topic starter
« on: August 13, 2014, 02:38:18 pm »
I have battery operated application, in which I have to transmit data at 4Khz.
Each sample contain 32x9 = 288bits.
Is there any wireless IC/module which can tranfer 4Khz samples with each sample having 288 bits at very low power. i.e
4Khz x 288 = 1152000 bits/sec
Offline sunnyhighway
Re: Wireless transmit large data/low power
« Reply #1 on: August 13, 2014, 04:44:50 pm »
Not sure if the range is sufficient, but serial over bleu-tooth might work for you.
http://wiki.pinguino.cc/index.php/SPP_Bluetooth_Modules
